pulling the steering wheel on a B2910
   / pulling the steering wheel on a B2910 #1
cmhyland
Platinum Member
Woodstock Valley, CT
2000 Kubota B2910
Hi guys,
I had a hydraulic line for the power steering blow. To replace this you have to pull the black plastic cowling nd instrument cluster to access the power steering box.
I'l having a hard time pulling the steering wheel. not much steel in the base of it for the wheel puller to grab onto. Has anyone done this job before?
If so I'd love to benefit from your experience.
Regards,
Chris
   / pulling the steering wheel on a B2910 #2
Thanks Pacer.... Too bad I didn't get your post until after I came back from Harbor Freight... I can run back tomorrow and pick that up....
This is one of those jobs it takes you 5 hours to get access to spend 5 minutes changing a part....
Regards,
Chris
Regards,
Chris
   / pulling the steering wheel on a B2910 #5
Hi guys,
Regards,
Chris
This is not an easy job when they are stuck
Penetrating oil and prelod the steering wheel with a puller, Tap the shaft if possible or if not he wheel.
Come back an hour later and repeat, and repeat.
Hopefully it will pop off at some point.
Thanks Mike,
I picked up the puller that Pacer recommended.... the wheel was off in 5 minute.... It had PB Blaster soaking on it for a few days... The clamshell puller was the way to go...
It's a PITA to get the cowling off. My tractor has a mechanical tach so you have to unhook the cable to get the cowling and instrument cluster to move...
Once I got it moved aside enough, I was able to change the hydraulic line in 15 minutes....
So 3 or 4 hours to take apart, 15 minutes to change the line and 30 minutes to put it all back together....
Thanks for the help everyone....
Regards,
Chris
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A53426)
2020 CHEVROLET...
2008 Chevrolet Express 2500 Passenger Van (A51692)
2008 Chevrolet...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
John Deere GR72B 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
John Deere GR72B...
