Pulling shrubs/small trees
   / Pulling shrubs/small trees #1
flyer
Ithaca, NY (upstate)
1989 John Deere 855
I'm looking for some clever ideas: how do you guys best pull unwanted shrubs and/or small trees? I've tried the tractor and chain and the chain never fails to slip off and over the darn things, no matter how tight I get it ...
thanks!
   / Pulling shrubs/small trees #2
thanks!
I have used the 4 in 1 bucket to grab small trees. I lift and wiggle in all directions. I also use the teeth on the bucket to dig around the tree and cut through some of the roots. If the ground is damp I can pull up a six inch stump. Also I grap the tree about 2 or 3 feet off of the ground, to give more leverage when wiggling it.
   / Pulling shrubs/small trees #3
Hook the chain on the tree or shrub as low as you can, Then roll a large log up to it, Put chain over the log, Hook to tractor or truck and pull. It will lift and pull it out.
   / Pulling shrubs/small trees #4
A good length of rope and the knowledge of how to tie a proper knot will work wonders.
Today I tried an experiment that was quite a success. I adjusted the pallet forks to their narrowest setting. The blades were only an inch or so apart. I then treated the blades like a shovel and proceeded to take out 7-8 locust trees ranging in size from 1/2 inch to 3 1/2 or 4 inches in diameter. Wow, what big roots these things have! Worked pretty good, kinda like a sharpshooter spade. I didn't have to manually handle the darned thorny things as only the pallet forks touched them.
A smaller diameter chain like 1/4 inch is better than say 3/8 or 7/16 for pulling brush (if within the strength of the chain) but I have used the larger stuff with success. The key is in knowing how to take advantage of the "CAPSTAN EFFECT." You need to know how to wrap and tie/connect the chain so that under tension it constricts and grips tighter but when you relax the tension the chain is very easy to remove.
Pat
   / Pulling shrubs/small trees #5
I like Pinemountainman' way. Though I used an old truck rim. If you have enough power, they'll pop up and out.
Have fun!
BD
   / Pulling shrubs/small trees #6
Simply wrap the chain around the tree or stump starting low to the ground and be sure to get at least a half dozen loops. Then hook the chain back on itself and pull away. The chain will tighten on itself and rarely slip. When I was clearing my property to build a few years back, we pulled hundreds of small tree stumps this way ( up to about 5" diameter) with a 50 hp. Oliver.
Best of luck
   / Pulling shrubs/small trees #7
several forks on the bucket will also work well as another poster has stated.:D
   / Pulling shrubs/small trees #8
I use my PHD to punch a couple of holes around the Base and either push them over or hook a chain on them and pull them put. A car or truck rim will help a lot too
   / Pulling shrubs/small trees #9
BD, You still need the chain to hold and not slip. The rim or whatever just serves as a turning block to give you a more vertical pull instead of a horizontal pull. This increases the efficiency of your pull by directing the force in the right direction. IF the chain slips instead of holding the rim or whatever won't help much.
Shawn stated the best and simplest way to incorporate the capstan effect, multiple wraps (more are better but don't go crazy) with the pull applied at the bottom of the wraps and the top wrap secured back to the chain. It works on friction between the chain and the object to be removed. You will get better contact and more friction with a chain that isn't grossly oversize. It is important to not let there be much slack in the top part of the chain as the slack will work down into the wraps and they will loosen. You want the wraps to tighten up like a python when you pull up on the bottom part.
Pat
   / Pulling shrubs/small trees #10
I have always had very good luck by putting a choker around it. You make a loop in the end of the chain then you feed the other end around the tree or bush and through the loop. If it is done right the harder you pull the tighter it will cut into the tree.
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2009 Pontiac G6 Passenger Car (A51694)
2009 Pontiac G6...
2006 GAYLEAN  130BBL (A52472)
2006 GAYLEAN...
