JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,023
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
Remember that drawbar pull is not the same as how much weight it will pull when the weight is on wheels or skids.
Here is a good start:
Tractor drawbar pull - AnandTech Forums
"From a review I was able to find, a Kubota BX23 tractor was able to pull 750LBs in 2WD, 1420 in 4WD, 1760 in 2WD w/ 600LBs of ballast, 1920 in 4WD with 600LBs of ballast, and it has an operating weight of 1520."
Bruce
Any car/truck/tractor wheeled & powered device can pull no more than it's own weight , I hasten to say with some specific exceptions. As a physics problem the 1:1 weight to pulling force ratio only happens when the coefficient of friction is perfect. As a practical matter the coef of friction is rarely as much as 1.0 so the tractor "can" pull something approaching its' own weight under best of circumstances. I assume through all this discussion that the tractor can, with gearing, pull more than it's own weight aside from traction issues. It should be noted that in some momentary circumstances with Ag tire lugs sticking down into ideal just-right-strength soil the coef of friction in effect goes above 1.0 In other words the cleats of the tire have penetrated the ground and are pulling against the ground along the direction of travel, NOT depending on friction. Like climbing a horizontal ladder.
All that out of the way, the review bcp found is probably a very good source of info. But be skeptical of what you read -- the quoted review says that the BX23 pulled 1920 lbs of force while weighing 1520 lbs !!?? No it did not, not unless it dug into the ground somehow while pulling in order to exceed 1.0 for a coef of friction or was loaded with some weight to make it heavier.
I did not take time to look, but Jerry in post # 7 mentions the Nebraska Test Lab. If anyone has authoritative data on what a tractor will pull it would be the Nebraska Lab. If they do have data, they will spell out exactly what the conditions are.
And finally, the 5:1 block and tackle that Tractor Dell has is irrelevant in terms of what a BX23 (or any other machine) "can pull." If you hook one end of a glorified block and tackle (who cares how many pulleys) to an immovable object (like a tree or other anchor of some sort) then any pulling source of force -- say a man walking along pulling on the rope or chain -- can produce as much pulling force as you choose based on the mechanical advantage he has via the force multiplier of the block and tackle. That is meaningless except that what the OP called a "5 pulley system" may well be an asset that he has and can apply in his circumstance. Has nothing to do with what a BX23 can or cannot produce in pulling force.
