Pulling disc with e hydro
/ Pulling disc with e hydro #1
SCDolphin
Columbia, SC
Kubota L5240: Craftsman GT6500
I have several 20 acre fields I would like to plow with a 6-7 foot disc. Can I pull it with e hydro vs manual transmission. Several JD dealers have told me if I plan on pulling ground engaging equipment that I should stay away from e hydro because it will overheat. I have not been told this about Kubota Hydro's
/ Pulling disc with e hydro #3
I pull a 6' disc with my JD 4720 e-hyrdo without a problem. I did 80 acres with it - no problem. I got very familiar with the cruise switch doing that project - yoiur ankle will be hurting by the end if you dont use the cruise.
Which tractor will you be using?
D.
/ Pulling disc with e hydro #4
D.
/ Pulling disc with e hydro #5
Their advice is true largely for serious AG use. You should be fine. But you will certainly need to watch your maintenece no matter which brand, use the best fluids, do all proper checks...
/ Pulling disc with e hydro #6
/ Pulling disc with e hydro #7
I'd think a big factor on the overheat would be the type of soil you have and how deep you plan on going.
Say you're wanting to get down 6 inches, taking 3 inches and letting dry a couple of days before trying to get the rest of the way down would put less pull on the hydro than trying for all 6 inches at once.
/ Pulling disc with e hydro #8
/ Pulling disc with e hydro #9
You should have no trouble doing the discing. I use mine to bottom plow ( 3- 14) about 12 acres, and some of that is in clay soil fields. No over heating in 170 hours.
/ Pulling disc with e hydro #10
/ Pulling disc with e hydro #11
I pull a 10' JD Model KBA disc with my 4310 E-Hydro in "A" range with no problems on some very hot days. Deere dealers find manual tranny models harder to sell than E-Hydro's so they'll push the manuals if they have a chance.
/ Pulling disc with e hydro #12
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
JOHN DEERE 7420 TRACTOR (A63291)
JOHN DEERE 7420...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
8' DISC HARROW (A60430)
8' DISC HARROW...
JOHN DEERE 1700 - 8R30" VACUUM PLANTERS (A63291)
JOHN DEERE 1700 -...
