pulling a white 348 plow
   / pulling a white 348 plow #1
ny
jd 1070
hi i have a koubota m 6060 4 wheel drive tractor loaded rears and front loader is my tractor big enougth to pull a white 348 mounted 3 bottom 16 inch plow thanks art
   / pulling a white 348 plow #2
should do fine
   / pulling a white 348 plow #3
I pull a set of 4X16 semi mount plows with an 8540, 4wd, loaded tires. It pulls fine in corn stubble, a bit tough in sod.
   / pulling a white 348 plow #4
as long as you gear down in low range & keep the power curve around 22-2400 rpm you'll be fine. if you bog down, choose a lower gear.... if you're willing to take your time & fine tune, you'll be just fine.
2011 Deere 650J (Camilla, GA) (A50123)
2011 Deere 650J...
2002 Genie Z34/22 34ft Electric Telescopic Boom Lift (A51691)
2002 Genie Z34/22...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
78in Screening Bucket Skid Steer Attachment (A51691)
78in Screening...
UNUSED FUTURE HYD 12" AUGER (A51248)
UNUSED FUTURE HYD...
UNUSED FUTURE FT15J EXCAVATOR (A51247)
UNUSED FUTURE...
