Pulled this old Oliver out of the field...
   / Pulled this old Oliver out of the field...
This should be it.
Bruce
Thanks Bruce for fixing the link!
After all that work, you have to paint it all !
oh man...thats too much. Can't do it. :D
Sounds healthy Mdude ! Great progress getting her fired up already :thumbsup:
Thnx for the repost Bruce.
Rgds, D.
Purrs like an angry kitten... :thumbsup:
Thanks. I'll order a carb rebuild kit, the floats are sticking, dumps fuel right out the air inlet. A little bit of tuning and it'll be done. I gotta hook up the cooling system but now this aftermarket thermostat is giving me fits. Of all things, I sure wish they could get aftermarket parts right.
Sounding better! Squirt some ATF in the carb to lube the valve guides and put a timing light to that beast. It wants to roar!
It sure does! I got some tuning to do!
   / Pulled this old Oliver out of the field... #82
Been following since day one, great work! Watch that hot exhaust looping around near the battery!
Just looks super close in the video. That's a sweet Oliver!
   / Pulled this old Oliver out of the field... #83
Congrats on getting it running again. It gets to live again. :thumbsup:
So I got rid of the generator and I'm going to use a Denso mini alternator 45 amp. Had to make a simple little bracket, and finally got the belt sizes right. Lol. Just got to put the radiator on and hook up the hoses. Wednesday my carb rebuild kit will be here.
   / Pulled this old Oliver out of the field... #85
Why not paint the engine block and frame, now that it's starting to look so pretty?
   / Pulled this old Oliver out of the field... #86
Have you checked with a NAPA store for a water pump?
The ol girl is looking good.
I'll get there little by little, as I fix and replace things, I'll clean and paint. :)
Thanks. I didn't check there, but I found one that worked okay, from AllState AgParts.
Radiator is on and I was changing the power steering lines from regular hose and hose clamps to something a little more fitting. Lol.
I just used -8 hydraulic crimp fittings and hose. I'll replace the lines that go from the column to the pump as well.
   / Pulled this old Oliver out of the field... #88
Can I put a plug in (pardon my pun) for new plug wires? Those crackly paint ones are out of style. There are some suppliers that produce yellow insulated plug wires.
   / Pulled this old Oliver out of the field... #89
I like how Napa is proud to put city of manufacture on their filters; assume that's where Wix plant is. North Carolina made, all good....
Same issue with whether to paint or not with my new to me 1955 Super A, just as peely and nasty looking as this tractor, but so far I'm doing just what Mopardude is doing.
Though I can't wait to degrease and gently wash off. My 4000 psi powerwasher would take every bit of remaining paint off, but when something that looks
old runs young, well that at least to me can be more interesting.
Unlike Mopardude I'm no mechanic so my tractor still isn't back from the shop. In fact, it hasn't set foot on my property yet, went straight to dealer to do much of what OP is doing here.
As far as painting engines and anything really old, I spent three years as a yachtbroker in Fort Lauderdale and went out on about sixty marine/engine surveys. One of the worst things anyone could do to the market value of the yacht was take a can of white spray paint and paint an entire Cat 3208 or even the B and C Cummins all white, electrical wires, you name it, everything got painted. I happen to think painting electrical wires is bush league but no offense to anyone else meant, I go through a lot of blue tape when painting. Painting the whole engine usually meant something was being hidden. Fresh paint shows leaks better though...and most of these old unrestored tractors are drippers. Like the 8V71TI Driptroits I used to own.
At some point if you fix/replace enough parts with new it does look a bit odd, shiny bright parts against the speckled background.
But that's what a real farmer would do, back in the 50's...
Today I think we wax tractors more than most folks used to wax their cars. I do....;) But that's on a new/newer nicely painted tractor.
I look at the old scratches and wonder how did they do that? Probably would have made a good paleontologist...
Nice high resolution photos
   / Pulled this old Oliver out of the field... #90
Any chance of curving that hydraulic line back inside the body of the tractor?
I hate to see hydraulic lines exposed like that, particularly in the front of the tractor.
Sturdy hoses were put on, just might get overly exciting spraying hydraulic oil on a hot engine if snagged.
Unless it was just the angle of the picture. Maybe put a protective sleeve on it if you can't reposition it.
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2000 International 4800 (A53314)
2000 International...
1839 (A51248)
1839 (A51248)
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
Eager Beaver 20XPT (A47477)
Eager Beaver 20XPT...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50775)
2022 Case TR340B...
