Pulled the trigger - L3200 HST with FEL and Landpride Cutter
   / Pulled the trigger - L3200 HST with FEL and Landpride Cutter #11
Make sure you add cruise control to it.
   / Pulled the trigger - L3200 HST with FEL and Landpride Cutter #12
In answer to the question does the tiller cover my tire tracks, haven't noticed any problems either way, as tiller is pulled by tractor. But on looking at spec sheet, it said tractor is 53.7 inches wide, and I have rear tire spacers, which should make mine around 56 inches wide. I was thinking about how to use the tiller in combination with my other tools, to make a garden efficient, and plan on tilling a swath, and skipping a swath, to allow me to have two planted rows, and then a path thru the garden to drive thru with the Big Red, to make it easy to work and harvest. I love the way the tiller works the soil, and plan on tilling once, then using the FEL to mound up two row of compost that I have been saving up and turning over for the last eight years, then re-till hoping that will help mound up the two rows, then finsh off by hand. By having only two rows, back to back, and large areas to work them from on either side, hope to be able to work, and harvest really easy. I know this method will take up more space, but will be worth it.
   / Pulled the trigger - L3200 HST with FEL and Landpride Cutter #13
enjoy your new tractor.
   / Pulled the trigger - L3200 HST with FEL and Landpride Cutter #15
Congratulations on the tractor. How much was it to add the cruise control?
   / Pulled the trigger - L3200 HST with FEL and Landpride Cutter #16
Congrats on the new tractor. I love my L3200!!! I believe you will too. Great choice.:smurf:
   / Pulled the trigger - L3200 HST with FEL and Landpride Cutter #17
If you don't mind, what did the L3200 run you? I'm looking at it as well for my 18 acres.
I was just over $20K having added 3 rear remotes, cruise and the FEL. However, you may be hard pressed to find one if you don't move immediately. They have ceased production of these tractors and are switching to the follow on models which will be tier 4 emissions compliant.
Polaris Ranger 1000 4x4 Utility Cart (A51694)
Polaris Ranger...
TRAILER AXLE (A51244)
2017 CATERPILLAR 304E2 EXCAVATOR (A51242)
2017 CATERPILLAR...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
