Dirt Moving Pulled my first stump with my new to me KX121
   / Pulled my first stump with my new to me KX121 #11
I find that if I get fishing line and shoot an arrow about 40 or so feet up over a major limb, then pull a rope up then I dig around the bottom on 3 sides (Leaving most of the side I am pulling toward. Then give a pull with the tractor I can bring it down easily. I sometime do as LD1 and just use the mini and push it over but sometime they can really hold on and the tractor gets me a bit farther from the action. Sometime amazing how hard it is to get a tree pushed over! I take a lot of dead trees down so I don't like pushing directly on them a whole lot with the mini because there are a lot of dead limbs above me thus the rope thing....
That is a nice size stump and your 121 is a great machine for popping them out!
You will learn going forward.....that if stump removal is in the cards......dont cut the tree down. Dig a little around it.....reach up high, push it over. Amazing what 10' of tree trunk for leverage can do.
Nice work on that stump.
I like that idea LD1.
Got it roughed out, the blade sure is handy.
Another good idea Code54
   / Pulled my first stump with my new to me KX121 #15
Yea, anything that makes it an otherwise dangerous tree, better safe than sorry. But with the reach I have with the backhoe, IT keeps me pretty far away already. Plus the 4-post metal cab is pretty stout.
I ripped out probably a hundred trees ranging from 10" up to ~30". Just use the ripper a few passes each side, reach up and push over.
Some were ~25"+ cotton woods (poplar family). Those were easy.
Similar sized ash trees....easy.
Maple....quite a bit tougher as they send big roots out in every direction. A 25" maple.....gotta start the ripper a good 2' away from the trunk, and even 2' away there are 8" roots to try to break.
But I think the hardest of what I had was the mulbury, and elms. None of those went willingly. But I dont think any of them took more than half an hour.
Which reminds me......if you plan on doing much more stump/tree removal.......you need to get yourself a ripper.
   / Pulled my first stump with my new to me KX121 #16
I wonder if I could mount a 2 foot ripper on the right side of my old Kubota bucket? I was thinking about maybe a 2 inch hitch reciver (long one) and build a ripper that hangs down about 2 foot below the bucket. Easy to remove in a couple of seconds, do you think it would work?
   / Pulled my first stump with my new to me KX121 #17
What's the intended purpose? It's gonna struggle ripping roots of any size.
My backhoe has something like 13,000# force at the bucket and like 8500-9000# with the dipper. And there are times it struggles with 4-5" hardwood roots.
For plucking out saplings, or 6" trees, it might be useful though. But I would worry about racking the loader with it hanging off one end.
   / Pulled my first stump with my new to me KX121 #18
If you back drag with your bucket it puts your curl cylinders in compression, where they are their weakest. With no lateral support they are very likely to bend. I lucked out before I knew better. Bucket spade on my pallet forks back dragging scraping & clearing out a trench to bury some drain pipe... fork popped of the frame before I bent a cylinder.
If you are talking about dripping going forward I'd be worried about wracking my loader. ESPECIALLY if it was not center mounted.
Your best bet would be a subsoiler or the like on your 3pt. It's designed for pulling stresses.
   / Pulled my first stump with my new to me KX121 #19
Have to agree - thinking a 3pt subsoiler/ripper would be the way to go.
   / Pulled my first stump with my new to me KX121 #20
I think it would bend too easily.
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
1996 INTERNATIONAL DUMP TRUCK (A57192)
1996 INTERNATIONAL...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
