Pulled an old Ford out of bushes and found out why it was there
   / Pulled an old Ford out of bushes and found out why it was there #31
I agree, run compression on all 3 cylinders and see what you have. You might have some sticking rings from sitting for so many years. You can free them up a bit by putting PB blaster or other penetrating oil down each bore and letting it sit and soak. The blow it clear before reinstalling the injectors and trying to start. I had an old 6.2L GM diesel like this, once it sat a few days with blaster in each bore, compression came up enough on several cylinders that it would run, once she had warmed up and put thru her paces all was fine. Diesels do NOT like to sit unused. They like to be run and worked. Good Luck. Mike
   / Pulled an old Ford out of bushes and found out why it was there #32
I would be looking at pump timing. Pull it down, pop the cover off the back by the flywheel, and make sure #1 is on tdc. Should be a mark on the crank pully and a mark on the cam gear as well. The marks you are seeing is the same as setting the advance on an old distributor, not setting the timing. If I had to guess the previous owner lost an injection pump (pretty sure these are a cav(lucas)pump, and cranked it with too much ether, which bent the push rods (hopefully that all he bent, seen trucks and tractors lift heads and bend connecting rods alot). I almost bet your timing is of and its shooting fuel at the wrong time causing detonation.
   / Pulled an old Ford out of bushes and found out why it was there #33
Was just reading this thread - wondering if you've got it going yet?
What's news on compression test?
Also, does the injector pump shaft have a master spline? I remember most I've seen do, and will only fit in one position.
If it doesn't, or if it still doesn't run, maybe the pump's been timed on exhaust stroke instead of compression stroke. This could explain white smoke = atomised, but not heated or even partially-burnt, diesel fuel. You need to ascertain No1 cyl is on TDC compression (or firing), then line up pump "O-Line" then engine should start (barring air locks in fuel system).
Keep us informed! :drink:
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2008 FORD F-750 (A50854)
2008 FORD F-750...
2013 John Deere 824K (A52128)
2013 John Deere...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
