Snow Equipment Owning/Operating Pull type snowblower on kubota bx2380
   / Pull type snowblower on kubota bx2380 #1
MathUdeS
Kubota bx
I am currently looking to buy a kubota bx2380. I would like to keep my loader in front all the time. I need to clear approximately 1 mile of driveway. When I look to buy a snow blower, there doesn't seem to be any inverted that would fit on subcompact tractor models like the bx. Anyone have any idea why or suggestions?
   / Pull type snowblower on kubota bx2380 #2
My guess would be that an inverted blower needs a tractor with a good deal more ground clearance than a bx to really be helpful.
Good luck in your search, however.
Frank
   / Pull type snowblower on kubota bx2380 #3
Blowing a mile of driveway with a bx23? Bring a snickers:D
   / Pull type snowblower on kubota bx2380 #4
Pull type blowers demand that you drive the tractor through the snow first and that BX doesn't have much ground clearance. Maybe 2 snickers?
What did you mean when you said "2 snickers" ?
   / Pull type snowblower on kubota bx2380 #6
Hello and good morning MattUdeS,
The issue for a small inverted snow blower is the need for power and the need for adequate traction/adhesion that you need to do the work at the same time.
The BX 2380 is too small in horsepower and weight for a hydraulic power pack driven front mounted blower.
Many of the forum members use mirrors or side side saddle while in reverse to save on neck strain and they also use
cameras to watch the rear.
When you getting in to front mounted blowers your talking significant monies and their are motorized snow blowers
you could install on the loader mount but the ability to raise the loader bucket will be limited even with a rear weight box.
I absolutely hate the front mounts offered today because they are 2 stage and the majority of them are belt driven.
The units offered for the sub compacts and compact tractors are underframe mounted and VERY VERY expensive.
The rear mounts for the three point hitch are much less expensive and there are several brands made in Canada and
the United States that are very well built and one brand I would avoid like the plague that is made in china.
I would be worth your while to look at the B23S? with the cab and a good Canadian rear mount snow blower very quickly
as the longer you wait the likely possibility of not being able to obtain a good rear mount will be come impossible.
Having a cab will let you work in shirt sleeve comfort and have good lighting and a radio if you want one to pass the time.
The multiple blessings for a rear mount snow caster are
(1)better visibility
(2) ease of maintenance
(3) lower initial cost
(4) simple mounting system that will not bite your ankle or trip you in the dark
(5) no reversing gearbox drive using a chain drive
(6) 540 RPM drive system versus the 2,200RPM+ mid mount drive system
AND (7) HIGHER GROUND CLEARANCE that the front mounts will never have.
In any case you need good chains and loaded rear tires to save time and effort to limit slippage and obtain adequate adhesion-YOU must remember at all times
a very small portion of each tire is in contact with the ground at any time while driving forward or reverse.
Driving in reverse takes a little practice and many members use wider rear mounts and drive a bit slower in reverse for the first pass and then are able to travel faster
in reverse for the next passes to clear the snow pack.
If you have that much driveway a mid sized used diesel row crop tractor with a rear mount snow blower with a new 6+ foot cutting width may be a better fit for you as it will most likely have a heated cab, good lights, 4 wheel drive and a hydrostatic transmission.
Leon
   / Pull type snowblower on kubota bx2380 #7
He means candy bars.
Add a thermos of coffee to that along with amber skiing goggles.
Me I would prefer Hershey bars and Almond Joys in the tool box to keep them cold.
   / Pull type snowblower on kubota bx2380 #8
I would agree, for the long drive, you need a larger tractor. At first I did a half mile with a Case 446, four trips up and down got the job done. It did have a home built cab, beats a walk behind. New tractor has comfort.
   / Pull type snowblower on kubota bx2380 #9
Have no idea where you live or your snow conditions, but I would recommend a truck with plow for a mile of drive.
It will take a good amount of time and fuel to clear that with a BX.
   / Pull type snowblower on kubota bx2380 #10
Snickers candy bars......a good snack if you are out in the wilderness for a very long time. A one mile drive with a small BX and blower would be very slow going and it would be best if you packed sustenance.
Mini Skid-Steer Forks (New/Unused) (A59225)
Mini Skid-Steer...
2248 (A58376)
2248 (A58376)
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2024 Yakta YXR610 Zero Turn Lawnmower (A57453)
2024 Yakta YXR610...
2322 (A58376)
2322 (A58376)
Bush Hog RDTH84 (A57148)
Bush Hog RDTH84...
