Pull Those Skid Plates!
   / Pull Those Skid Plates! #1
JESSE1
Veteran Member
Kilgore, Texas
JD 6400
I'm doing service on my RTVX-1100C which requires pulling the rear skid plate to change the engine oil. This time I figured it would be a good idea to drop the front skid plate and clean it. Good thing I did because there was probably 50# of mud on top of it that can't be removed unless the skid plate is pulled. I'll spray water and clean the chassis while it's off.
I'm also changing the hydraulic tank oil and trans oil. I'm using the synthetic Kubota UDT2 trans oil. Pretty expensive at $125 for 5 gallons but supposed to provide better performance and temperature protection. I use the Kubota 15w40 oil in the engine.
It seems like the synthetic trans fluid is making a difference in performance. In one stretch of the pasture I usually can barely get up to 21 mph, after the fluid change I can easily hit 24 and got 25mph before I had to slow down. The trans response seems crisper, too, where it was a little sluggish.
   / Pull Those Skid Plates! #3
I have pulled a few of mine in the past and found the same thing...Need to do it again and paint up some of that stuff...Snow plowing is my rust enemy (at least it hasn't really kicked in since I keep it indoors and clean--mostly)
   / Pull Those Skid Plates! #4
To keep the rust at bay Fluid Film is tough to beat.....a quick coat and it won't rust. I use it on equipment and my trucks to combat the calcium they put down on the roads up here...works excellent and is very reasonable.
   / Pull Those Skid Plates! #5
I have some of that and agree---although it's like anti sieze, just look at it and it's all over everything.:(
New Calf Hut (A50515)
2020 CATERPILLAR 242D3 WHEELED SKID STEER (A51242)
2020 CATERPILLAR...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
