Pull Shaft Weldment
/ Pull Shaft Weldment #1
Gizmo36
Platinum Member
East of Duewest S.C.
I am work on a Bottom plow , Can some one tell me how far down I need to put the Lift Pin on the left of the Pull shaft. I think it is 2 1/2 but not sure.And the 5 holds for the setting are they 1/4 apart or closer .I am taking a pull type and making a 3 pt .
Dose no one have a Worksaver Bottom Plow .That can give me a measurement.
This is a 2x14 MT John Deere Bottom plow a friend on here let me have.But it is only good with the JD MT. I am trying to make a 3 PT hitch out of it . And save the spring trip if I can.The tail wheel is on wrong but have not had time to take it off yet.
/ Pull Shaft Weldment #6
My plow is different from the one pictured. The frame is a 2" square tube not a shaft, however the offset of the pins is 3". Don't know if that helps or not. You can always adjust your 3pt arm height to get the plow set right.
From the center of the right pin to the center of the lift pin is 3". is that right . They have them close and if I put them the way they have them . I want have to move it much.
Customization this plow has stop.The rubber ban that goes around the wheel that keeps the blade from slipping broke on my porter ban .any one know were to start looking for one .I know no one that sales parts for a porter ban.
Farmwithjunk if you have time I need some help . we got the church done now I am going to work on my thing.
Gizmo36 said:
Farmwithjunk if you have time I need some help . we got the church done now I am going to work on my plow.
I am trying to change this to plow .
I went back to edit it, but it turn in to a post.It did not edit , and that did not sound good at all did it.
/ Pull Shaft Weldment #15
Gizmo,
This looks like a great project. PLEASE keep a running update on your plow project for us. This is better than any television series!
Thanks.... BD
