pull roofing nails out of rolled roofing without tearing
   / pull roofing nails out of rolled roofing without tearing #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Need help >
How do I pull roofing nails out of rolled roofing without tearing it up so I can lift it up and slide flashing up under it?
Need tips ideas and suggestions.
   / pull roofing nails out of rolled roofing without tearing #2
use a four inch grinder and grind the head off the nail......Larry
   / pull roofing nails out of rolled roofing without tearing #3
Hammer them back out from the bottom (under roof), then pull from the top. Is this on a house or a shed?
A small 6x6 porch.
The nails go into the rafters not between them.
So they can't be driven out from underneath.
   / pull roofing nails out of rolled roofing without tearing #5
Pry bar slid up underneath and then lots of silicone after you are finished.
There are nail pulling tools out there.
You may be able to get a side cutter under the head and pull them up that way.
Prepare for damage to the existing roofing and have plenty of silicone on hand to patch after you are done.:D :D
You may also be able to use a torch to soften up the area aroud the nail to make it easier to get a grip on the head.
I thought about grinding them off or taking a drill bit slightly larger than the shank of the nail and drill the head off than way.
Another idea was take a utility knife and cut through the roofing around the nail heads, but i don't really like having a 1/2" round hole to patch in the roofing where the nails were.
I know i have my ideas on this but i also know others may very well have better solutions, hence why I started the thread.
   / pull roofing nails out of rolled roofing without tearing #7
Go to your local roofing supplier and just buy a roofing nail puller and you will be a happy camper and I don't think silicone will work very long, you should use a roofing patch material, kinda like roofing tar
Happy Veterans day to all :)
Jim
Thanks all for your tips;
Got the job done.
Used a putty knife to gain a little space under the nail then used a cats claw to get under the head and pulled the nail right out.:)
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
RIDGID POWER DRIVE/HAND HELD THREADER (A53843)
RIDGID POWER...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53473)
2017 Ford F550...
5- RIGID 65-R THREADERS (A53843)
5- RIGID 65-R...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A53473)
2019 BOBCAT T630...
