Pull out the choke, turn on the ignition, step on the starter
   / Pull out the choke, turn on the ignition, step on the starter #11
My 49 Willys Overland had the starter on the floor, 3 on the tree with dashboard overdrive. What a tank. 50 top speed in OD.
Lot of them had 5,36 gears. Some had 5.13 ratio.
   / Pull out the choke, turn on the ignition, step on the starter #12
520 Johnny popper, Super M Farmall, H Farmall, from 60s thru 86 when we sold the last one. Don’t remember if 52 Ford with flat head had starter on the floor though.
   / Pull out the choke, turn on the ignition, step on the starter #13
My father’s 1949 KB5, although I don’t remember ever driving it.
Every time I saw him start it cold though he would get it rolling backwards out of the barn, slip the clutch and it would start immediately.
His Ford 4400 was also like that.I got it going after it had been setting for about 5 years. Then we sold it. :(
   / Pull out the choke, turn on the ignition, step on the starter #14
Funny you bring this up because I just did it NEVER. Are we talking airplanes.
   / Pull out the choke, turn on the ignition, step on the starter #15
My Dads 39 Plymouth. We drove across the country pulling a home made trailer. Times were lean then.
   / Pull out the choke, turn on the ignition, step on the starter #16
Last was an old Gravely. Probably last car/truck was an old Studebaker.
   / Pull out the choke, turn on the ignition, step on the starter #17
I did it in my first car, a 1929 Model A ford coupe.
Plus several more after that.
   / Pull out the choke, turn on the ignition, step on the starter #18
59 Chevy 2 ton truck had the floor starter,
WD Chalmers had a pull rod to engage the starter,
Farmall 560 and 656 have push buttons on the dash.
Lots of other vehicles with manual chokes, some had the auto chokes removed and manuals installed.
   / Pull out the choke, turn on the ignition, step on the starter #19
Last time I did that was in 1971 driving my dads 1927 Model T Ford.
   / Pull out the choke, turn on the ignition, step on the starter #20
My Dads old Plymouth also had the high beam switch on the floor.
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
2007 JLG SkyTrak 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
1991 Great Dane 48' Reefer Trailer (TITLE) (A50774)
1991 Great Dane...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
FELLA TH800 HAY TEDDER (A51243)
FELLA TH800 HAY...
