Pull complete engine to check crank shaft?
/ Pull complete engine to check crank shaft? #1
Lee Confused
Ford Power Master Diesel
My 1955-57 Ford Power Master diesel tractor has a knock in the engine. It sounds like solid metal hitting tin, not the block. The pulley to crank shaft is off balance (but tight & secure). Do I have to pull the complete engine & take it apart to check the crank shaft?
-Is there a faster & easier way to check this problem?
Thank you,
Lee Ball - Confused
e-mail: robertandalyce@sbcglobal.net
/ Pull complete engine to check crank shaft? #2
you can take the pan off and check it.
/ Pull complete engine to check crank shaft? #3
You can drop the pan to check the bearings. Carbon on the pistons can also cause a knock. Can you crank the engine with the fuel shut off to try to isolate whether the knock is in the top or bottom of the engine.
Bill
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
