Pull-Back collar on PTO shaft
   / Pull-Back collar on PTO shaft #1
Jack42
Deere Model 3039R
Hi,
New member here with arthritis in hands. I just spent several hours kissing, cursing and aching, trying to get a very well lubricated driveshaft onto the Deere's spline. Damn thing kept insisting I buy it dinner first!
Short version, My hands (at 74) are no longer strong enough to Hold back the collar to release the ball bearings while pushing the shaft forward. I can still do the rods ok, and the twister ok, but the pull back defeats me.
Finally got it on with second person tapping on the collar as I pulled back.
Question: does anyone make a strong enough clip to hold the collar back until mounted?
or
is it easy to replace the pull back collar with a rod collar? or a twist collar?
   / Pull-Back collar on PTO shaft #2
G'day Mate and welcome to TBN from Downunder.
Did you raise the implement to a height where the driveshaft was parallel with the PTO?
   / Pull-Back collar on PTO shaft #3
This is what I did for a mid mount mower shaft. Can’t take credit someone else had the idea. Works well.
   / Pull-Back collar on PTO shaft #4
I hate those pull back collars! My solution was to replace the yoke with one of the push pin type yokes, I would have used the twist type if it had been available locally. If I remember correctly it cost about $40 to change it. Money well spent to no longer have to put up with the frustration.
   / Pull-Back collar on PTO shaft #5
All of mine are old and have the push-pin release. Even those can be cantankerous at times if not kept lubed. I have to make it a point to include them in my routine maintenance rounds as all my equipment is stored outdoors.
The hair-pin idea is a good one even if revisited. Was the "hole" already there? Ball removed? Drilled? :unsure:
   / Pull-Back collar on PTO shaft #6
Switching to the push pin type can help. Also, use a bungie cord around the top link to hold the pto shaft up. Then you can concentrate on getting the shaft connected. I can't take credit for that idea, someone here posted it. Most pto shafts will slide onto the tractor's pto stub for a short ways before you need to release the locking balls to fit it the rest of the way. You can slide it on partway then unlock the balls to get it on the rest of the way.
   / Pull-Back collar on PTO shaft #7
Maybe look into some of the new pto easy attach units. They are a little pricey but seem to make it very easy to connect. There are pop up adds on you tube for them.
   / Pull-Back collar on PTO shaft #8
You can swap out just the end of it (or pay someone to do it for you).
Not sure what kind of PTO shaft John Deere uses... if it's like anything else JD, they have a proprietary connection.
Agrisupply has other ends depending on the class of pto shaft: (not saying this one works)
   / Pull-Back collar on PTO shaft #10
I had a little go round with my blower shaft. Wound up putting on a hose clamp once it was pulled back. Worked pretty good.
2009 TRAIL KING PNEUMATIC TRAILER (A45333)
2009 TRAIL KING...
2023 Takeuchi TL10V2 (A44501)
2023 Takeuchi...
CIC Contractor's Crossover Toolbox w/ 3000W/6000W Inverter, Air Compressor, Jump-Start Capability (A44789)
CIC Contractor's...
W&A 3Pt Ditcher (A44502)
W&A 3Pt Ditcher...
John Deere 1025R 4x4 Tractor with Loader (A44391)
John Deere 1025R...
1973 Timpte 40-Foot Hopper Bottom Grain Trailer - Leaf Spring Suspension and Well-Maintained Tarp (A44789)
1973 Timpte...
