Pull a Subsoiler with B7100??
/ Pull a Subsoiler with B7100?? #1
Travelover
Elite Member
Washington
B7100
This may be a dumb question, but I'd like to put in some poly pipe and underground wires with by B7100. It has 4WD, but has turf tires with chains on the back. Soil here in metro Detroit is 6 to 12 inches topsoil over clay. Would a class 1 subsoiler from Tractor Supply just pin it to the ground or do I have a chance of using it effectively? Thanks in advance for any advice.
/ Pull a Subsoiler with B7100?? #2
I lent mine to a guy down the road and he pulled it with a 19 HP Kioti no problem. Make a couple passes at a deeper depth with each if necessay and you should have no problem. Good luck..
2022 EZ-GO ELITE...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2015 Isuzu NPR-HD Box Truck, VIN # 54DC4W1B3FS807576 (A65563)
2015 Isuzu NPR-HD...
IH International 1466 Tractor (A66285)
IH International...
10" Utility Blower Fan (A66408)
10" Utility Blower...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
