Puliing with ZD21
/ Puliing with ZD21 #1
beagdog
SE Kansas
Kubota L5030, ZD21, Cub Cadet 1250
Dealer delivered a ZD21 for me to try out tonite. I'm about to pull the trigger (trading G1900 4ws) but need to know if a trailer hitch is available and if so (or even if its not), has anyone that has a ZD21, ZD25 or ZD28 used it for towing anything? Should've asked the dealer, but it slipped my mind. I have a 50 gal pull behind sprayer and a 175# fertilizer spreader that I need to be able to use if I trade.
I have run the ZD21 about 15 minutes and I really like it, if I can't pull anything, may have to keep the G1900.
Any help appreciated, thanks!
/ Puliing with ZD21 #2
I've got a ZD28. Less than 50 hours, but so far real happy. I did wrap a chain around the frame to tow my mil's lawn tractor on my trailer to take for a service. Worked ok, but I got a feeling the dealer wouldn't recommend it. I don't know of a hitch for them. Someone just told me his ZTR manual says towing is a big no no. Damage may result. I don't know for sure. Seems like a waste to have a machine like this and not be able to tow anything.
/ Puliing with ZD21 #3
I have a ZD21 and I could swear I saw a Kubota accessory that was a hitch plate that bolted to the back.
I don't see where it would hurt to pull something as long as it wasn't to heavy. These were made more for speed than anything. But my ZD will pull my big butt up some pretty steep hills while mowing and not miss a beat.
/ Puliing with ZD21 #4
I remember a post with pictures of a rear bumper and hitch that a TBNer made. But could not find it. Here is a thread that mentions a place to look for information. Click Here
/ Puliing with ZD21 #5
They're probably concerned with how easy it is to jacknife the trailer against the ZD frame. Backing up would be even tougher. Now if there's any slope involved too, I'd place it somewhere between crazy and suicidal.
I almost bought a ZD, loved it until I brought it home and tried it on my obstacle laden slopes.
/ Puliing with ZD21 #6
I have a ZD21 with a trailer hitch. My dealer installed it so I'm not sure if it is a stock item. It is basically a L shaped piece of steel. I have pulled my 900 lb roller with it. I usually use it for pulling my 175 lb capacity spreader.
/ Puliing with ZD21
Thanks for the responses guys. I looked over the frame a little closer today and can easily fabricate something if its not a Kubota option. I just don't want to put one of my homemade creations on there if there's something out there that will look right. I only use both the sprayer and the spreader a couple of times a year, and would never use them on a slope.
I think I'm going to trade, even though I stuck the ZD tonite. Was mowing a ditch and pushed instead of pulled and got high centered (well actually end centered). Just going to have to get a little more finesse on the controls, hopefully that comes with time. Boy, is this a grass cutting machine!
Next question, if you'll indulge me, does anyone have the Kubota grass catcher on a ZD? I'm now torn about ordering one for this machine. I like the look of a swept yard, but the speed this thing chops the grass, not sure if its necessary. Thoughts? The dealer will cut me a deal on a catcher if I order one.
/ Puliing with ZD21
I've only run the ZD about an hour so far. I mowed on the weekend, so I really don't have any tall or heavy grass to try it on right now, but the quality of cut on what I have mowed (I usually mow at 4" and I lowered the ZD to 3 1/2" just so I could see how it mows) is unbelievable. I'm struggling with the controls a little, I haven't run a zero turn since an early Excel Hustler in the late 70's.
The speed is also something I like about the ZD, but I'm still a little concerned about some of the bar ditches I have to mow. I think I will get better with time. Interestingly, there's a paragraph in the ZD manual that talks about operators over 60, that doesn't leave me a lot of years left to mow with it /forums/images/graemlins/grin.gif.
I'm not sure you can really compare apples to apples between the two because they are so different, but I was just ready for a change. I nearly bought a new Hustler Super Z but could buy this ZD with a diesel engine for only a few hundred more, and I'm sold on Kubotas. Also getting a reasonable (at least I think) deal on this machine with trade. The Hustler dealer wouldn't even talk about trading.
I agree, the G1800/1900 4ws machines are great, I had a G1800 for a year before I bought my G1900 about 7 years ago, and have never had to replace a single part. Hope the ZD is as durable.
/ Puliing with ZD21 #9
Dont bother with the grass catcher from Kubota. It has 3 seperate bags and everytime you need to empty it you have to get off the machine. I am looking into getting a catcher that you can dump from the seat. The company is Protero. They have been making catchers for years. The kit is about $2000. Its a lot of money thats why i havent bought one yet. Check it out.
/ Puliing with ZD21
Thanks for the tip. You just made my decision for me, I'll wait and check out the Protera. I like the looks of that dump box, much handier and I'm sure more durable than the Kubota bags. I'll check the current pricing, may price me out of the market anyway. Not a lot more than the Kubota catcher.
Thanks again.
/ Puliing with ZD21 #11
The only thing I don't like about my ZD21 is that is seems a bit underpowered at times. Like mowing up a steep hill really seems to slow the deck and machine to a crawl sometimes.
I would think a grass catcher might make it even more sluggish at times. On even grades and downhill it just buzzes right along and really throws the grass...
The one thing I learned very quickly in running a ZD is to not force the direction you want to go...it takes finesse.....For instance if your coming down a steep hill and want to slow down don't pull back on the handles as it will just break your tires loose. I found that if you want to slow down to just pull back gently in a quick pumping motion and it will give you better control as you come down the hill (kinda like anti-lock brakes) /forums/images/graemlins/grin.gif.
Actually after awhile once you get the feel of the ZD operation you really don't have to exert much force at all to get it to do what you want.
The other thing I can say that I learned is when doing a zero turn to go back in the other direction it is much easier on the grass if you do a 2 point turn. I usually get to the end and start backing up and then zero turn and it is much easier on the yard because your not actually turning from a dead stop and pivoting on one wheel.....It took a few yard divots to figure that one out. /forums/images/graemlins/grin.gif
Enjoy your machine...and before too long running it will just come natural. They are blast to mow with! /forums/images/graemlins/smile.gif
/ Puliing with ZD21 #12
I just finished the 300 hour service on my ZD21 tonight. If were to buy another Kubota, I would buy the ZD25 or ZD28. Just like jlbota said, the ZD21 is a bit underpowered. The extra HP will be handy at times.
When I buy another Zero turn, it will be Exmark all the way. I currently own a Exmark walk behind which is about 8 years old and never a problem....except regular wear and tear....tires, plugs, filters, etc.. Not to mention Exmark has a excellent cut.
At the very least, ask your dealer if you can try out the ZD21, 25 and 28 before you buy.
Curt
/ Puliing with ZD21
A few pics of the new ZD21. I decided to keep it.
#1
#2
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
