PTOs Shear Bolts Slip/Overrun Clutches etc
   / PTOs Shear Bolts Slip/Overrun Clutches etc #1
ballaterach
Aberdeenshire,Scotland
Iseki TX1510
As a very cautious newbie seeking more advice on PTO's etc. I have an Iseki TX1510 (Non Live PTO) and currently just a Rotavator which thanks to forum member is identified as a 4' King Kutter 2 Rotary Tiller (albeit perhaps branded under another name)The tiller manual states that all tractors not running a live pto need to have a PTO Overrunning Clutch. Some opinions say for a Rotavator that is not necessary. Any experience/comments would be welcome before I spend any more
money albeit I'm very safety concious !!! As regards the actual PTO shaft do these all come with shear bolt(s) as standard on the joints ? If not would these be an alternative to the overrun clutch or should I have these anyway?
Any advice gratefully appreciated. Thanks in advance
oh ps forgot to also ask many people mention having a Slip Clutch when using a rotavator any comments/advice welcomed on this too thanks
   / PTOs Shear Bolts Slip/Overrun Clutches etc #3
There is a diversity of opinion and some long threads on slip clutch vs shear bolt, so it's often a personal preference and sometimes different terrain may make one preferable over the other. I prefer a slip clutch for convenience and my brother prefers shear bolt for cost. A slip clutch requires more maintenance.
I prefer an over running clutch on every tractor. There are things you "can" get away with and running a tiller without an over running clutch may be one, I just prefer not to.
   / PTOs Shear Bolts Slip/Overrun Clutches etc #4
a tiller? IMHO..you don't need a ORC fro a tiller. 1, it's not alot of rotational mass.. 2, you are usually going about .2mph using a tiller.. :)
now.. a slip clutch.. SURE.. I'd deffinately use good torque limting on a tiller. shear bolt is ok.. but slip clutch is beter..
something with alot of rotary inertia.. like a brush mower is when you want an ORC... etc..
Thanks to all for your replies. Just reading the manual for the tiller it mentions a slip clutch on the PTO diagram page ......or is that something completely different? I'm assuming of course that the PTO shaft is the same as that in the manual!!
   / PTOs Shear Bolts Slip/Overrun Clutches etc #6
Some Manuals are not good at pointing out (if equipped) a lot are offered either with a shear pin or slip clutch and don't print separate manuals, you will be able to tell just by looking at the shaft. You can download a Land Pride manual or other brand and there will be a picture to use for reference.
   / PTOs Shear Bolts Slip/Overrun Clutches etc #7
slip clutches are torque limiting devices.
Over running couplers ( ORC ) are 1-way ratcheting dog clutches and only transmit power in direction.
they are not the same.. and have different purposes. one is to prevent drivetrain backfeed from a spinning inertial implement ( mower, thus ORC ).. and the other is to prevent drivetrain damage from hitting a n obstacle with a pto powered implement ( slip clutch )
thanks very much again still beeen reading up on slip clutches so where would one of these normally get fitted? some articles I have read mention on the implement in my case a rotavator(tiller)
   / PTOs Shear Bolts Slip/Overrun Clutches etc #9
depends. most add on slip clutches are attached right at the gearbox imput ont he implement. however on some setup, you can see a slip clutch at the tractor end of the pto shaft. all depends on setup. for implenents with a single gearbox.. I'd say it is common at the gearbox.. for multip gear boxed implements.. then ont he tractor end of the pto shaft.. etc.
2023 JACTO ARBUS-1000 LOT NUMBER 69 (A53084)
2023 JACTO...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
HITACHI ZAXIS 250LC-6N EXCAVATOR (A51246)
HITACHI ZAXIS...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
