PTO yoke replacement made easier
   / PTO yoke replacement made easier #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
My PTO driven post hole digger suffered a broken U joint and damaged yoke from operator error. The drive shaft is the tri-lobed type. I put the shaft in the vise, suitably protected from damage, and was able to drive off the damaged yoke with a hammer. I did this carefully so as not to damage the drive shaft. However, I could not easily drive the new yoke on without risking damage. Instead I used a 6 foot length of 1/2-13 allthread, two nuts and two heavy washers. I lived the threads where the nuts would be and by running the allthread through the hollow driveshaft i was just able to draw the very tightly fitting new yoke onto the driveshaft. 5/8-11 allthread would have been a better choice and if I ever need to do this again that's what I'll use. The upshot is that drawing the yoke on was very controllable and miles better than using a hammer for the job.
   / PTO yoke replacement made easier #2
Largest allthread that would fit would be the best choice. Good idea.
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
2013 Ford E-350 Cargo Van (A56858)
2013 Ford E-350...
2019 BOBCAT T590 SKID STEER (A52709)
2019 BOBCAT T590...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2009 INTERNATIONAL DURASTAR 4300 SBA ROAD TRACTOR (A58375)
2009 INTERNATIONAL...
