PTO won't engage
   / PTO won't engage #1
2515R Dude
Platinum Member
KY
Branson 2515R
The first time since i bought it i tried to engage PTO.
I turn the nob, the indicator light goes ON, i hear some noises from the transmission but the PRO is not spinning.
Any thoughts?
   / PTO won't engage #2
There is a lever on the left side of the seat, behind the range lever. On a 2515, it has 540 and Neutral position. Put it in 540, then turn the switch on in the Ind position.
   / PTO won't engage
Yes, just found it as soon as i posted this. . The life is hard for idiots :cautious:
Good thing it does not happens often.
Thank you anyway, you are a real help and throve of knowledge.
Why do they need two????
   / PTO won't engage #4
Since there is a spring actuated brake in the PTO clutch pack, that lever allows you to put it in Neutral so you can spin the PTO shaft by hand which helps tremendously when hooking up PTO implements.
It also gets a 540Eco position in the 30HP and above models, which is another great feature.
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
SCREENER (A50854)
SCREENER (A50854)
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
PALLET OF PICK BUMPERS (A50854)
PALLET OF PICK...
2005 Construction Trailer Specialists BDT-40 Bottom Dump T/A 40ft Trailer (A49461)
2005 Construction...
