3-Point Hitch PTO won't engage
   / PTO won't engage #1
ironhayden86
Moscow, PA
JOHN DEERE MODEL M
So I have a Ck3510 hydro and I was mowing my field and disengaged my mower why I drove to the next spot to mow and now the 3 poi t lever is stuck Rock solid. I call the local dealer and they said the is a updated part for the PTO engagement actuator. Has anyone else had this problem?
   / PTO won't engage #2
I had a similar issue but it started as the PTO level would disengage itself almost like it was due to vibration while brush hogging. Spoke to the dealer and they also mentioned an issue with the PTO. The day they came to pick it up I couldn't get the PTO to engage at all and seemed stuck. It has worked fine since repair.
   / PTO won't engage #4
Just for clarification, was it your PTO that was stuck or the three point lever itself?
   / PTO won't engage
PTO engagement lever sorry if I confused anyone.
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
EZGO (A50324)
EZGO (A50324)
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
