PTO WON'T ENGAGE
   / PTO WON'T ENGAGE #1
TomNarron
INTERNATIONAL 30
I am new to this forum and have a problem with the PTO on my Tractor.
It is a 1957 International 30HP Diesel. I was Bushogging and got the
blades hung up on a stump. The PTO disengaged and the Tractor stalled.
The tractor still runs fine , but the PTO won't re-engage. Has anyone
seen this problem before?
Tom
   / PTO WON'T ENGAGE #2
er.....not that tractor in particular, but i once thought my pto wasn't engaging, turned out the shear bolts on the pto shaft had sheared, and i couldn't see them under the plastic shield. the pto was actually moving fine. the shaft just wasn't engaging.
   / PTO WON'T ENGAGE #3
From your brief description, I'll take a wild stab, and guess it's a 350 Utility..?? I've attached an exploded view of the 350's PTO drive. In the parts description, it mentions a "seasonal drive". That would be in the box pictured below. This was an option, and may not be one yours.
Take your pick of the weakest links... The coupler ahead of the PTO drive shaft, or that seasonal coupler, if so equipped... Most of those internal PTO drive shafts on the smaller tractors were hollow tube shafts. If it stalled the tractor @ full throttle, and if it is not the shear bolts on the external pto shaft, there stands to be a good possibility you may have broken a coupler, split that tube, or broke a gear.
   / PTO WON'T ENGAGE #4
Problem could also be in the linkage that pressurizes the clutch pack.
Polaris Side by Side (A50324)
Polaris Side by...
Plastic Bear Statue (A55853)
Plastic Bear...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55314)
2023 Kubota M4-061...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
2012 Cadillac SRX SUV (A53424)
2012 Cadillac SRX...
