PTO won't disengage
   / PTO won't disengage
Hello CobyRupert - I had a topper on it a while back and I could not get it to stop rotating - I have seen and heard about PTO accidents so have no intention of going any where near it whilst the engine is running - not nice to be wrapped around that! Thanks
pto controls 1.jpgpto controls 2.jpgpto controls 3.jpg Here are some photos of the PTO control and cab controls
The manual I have is not quite the same as the controls - it shows a three position control with Neutral being in the centre, but I only have two positions for it to work in.
2 pososions...engage and disengage WITH at the back a choise of 540/ 1000 ?
Well that is an interesting question - at the back there is a small pull lever which seems seized at the moment - I have sprayed with WD40 and left to see if it will free up, but there is no mention of what it does in the manual, and I don't know where else a speed change control would be...
   / PTO won't disengage #18
Next....can you remove the inspection cover at the bottom of the bellhousing and take a photo of the pressureplate...mybe we can see if you have a ipto clutch or a dualstage clutch ?
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2020 Aluma 20' Trailer (A59814)
2020 Aluma 20'...
25ft Tag Trailer (A56436)
25ft Tag Trailer...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
