PTO winch
/ PTO winch #1
sherpa
Platinum Member
North Carolina Mountains
2004 NH TC33D & 2014 NH Boomer 24
I was thinking about getting me a winch for the rear of my B20 TLB tractor to operate off my PTO. (of course I would remove the backhoe). This winch would be used to drag logs off my hillside from fallen trees. I have not seen any PTO winches nor do I know where to buy them. I already own a 8000 pound electric winch which is attached to a 2 inch square receiver for use on my pickup truck. I could use it by making me a receiver for the rear of my tractor. I have been draging the trees/logs off by using a cable and chains. What do you guys think. Give me some input:
1-Get a PTO winch?
2-Use the 8000 pound electric winch off my truck?
3-continue using the tractor in low gear with a cable and chains?
Sherpa
/ PTO winch #2
Well, I guess one thing that would help in the decision is just how much fallen timber we're talking about. If it's just an occasional thing, use what you have. If it's going to be a regular chore, a PTO winch can save you a lot of time as well as wear and tear...plus ensure your personal safety. I use a Farmi winch for harvesting firewood, but Fransgaard and a couple of others are just as good.
Check with Steve Carver down there in your neck of the woods.
Pete
/ PTO winch #3
The Farmi's and others that Boondox mentions are first-rate but not easy to justify for personal use. Many build attachments using hefty used and/or surplus industrial winches configured for the 3-point. You can go either PTO or hydraulic.
Not as good as a Farmi but still much better than no winch.
/ PTO winch
Its just an occasional thing 3 or 4 times a year half a dozen trees each time but since I am the neighbor with the tractor there is always other uses and times in this remote area of western NC. Are you saying use the chain and cable or adapt the 12 volt winch up?
/ PTO winch #5
I have property in WNC mountains too and just purchased a Farmi 501. I ended up ordering off the net - today. If you need details send me a PM - I chose the Farmi over Fransguard and Tajfun due to price and feedback I received. Several people on here have purchased and have good input on the Farmi's. I hope to be one as soon as mine is delivered.
Tractor and skidding chain on steep slopes was not comfortable situation for me. I figured there would be many other uses for this winch as well. I also have about 100 trees to snag off the slopes.
Also an electric winch will work but you may need to by some additional lengths of cable to use due to amount spool will hold. Also, not sure how an electrical winch would hold up over period of time.
/ PTO winch #6
I think you'd kill a typical 12V electric Warn or equivalent pretty easily this way. I'd recommend sticking with the cables and chains until you find a heavier duty winch or get yourself into a Farmi or equivalent.
To repeat: Farmi-type is best. I just cannot afford one new and couldn't find a good deal on a used one so I'm in the process of adapting a 30,000 lb worm gear winch to a 3-pt setup. It will be slow but safe and reliable.
The best part is the $177.50 price /forums/images/graemlins/smile.gif
/ PTO winch
Man! I like the sounds of $177.50. And think of all the fun you are going to have making it!
/ PTO winch #8
PTO winches are very popular and do work well. I however built my own skidding winch using a 5-1/4 ton hyd winch and it is ways ahead of a pto setup. If I come to a mud hole in the trail I can let the cable pay out without ever leaving the seat. Once across just pull it back in.Try that with a PTO set-up. When using a hyd winch you should have a hyd oil cooler which my tractor has.
/ PTO winch #9
I was under the impression one could operate the Farmi from the seat as well. Maybe I misunderstood. I would hope I could let the cable play out from the seat too, but maybe not. I know one can use the Farmi to pull while in the seat, but not sure I want to try that one yet.
Your hydraulic set up sounds very cool. I would love to see some pics when you have a chance.
/ PTO winch #11
1bush2hog, I think there are some pictures in the "build it yourself forum. Do search for them.
/ PTO winch #12
</font><font color="blue" class="small">( I was under the impression one could operate the Farmi from the seat as well. Maybe I misunderstood. I would hope I could let the cable play out from the seat too, but maybe not. I know one can use the Farmi to pull while in the seat, but not sure I want to try that one yet.
)</font>
1bush2hog,
I have a Farmi. Yea, the controls will allow operation from the seat. Safety tells me to do otherwise... Having 100+ feet of cable out there in a line directly behind my seat generates too much pucker for me. I have a stretch of rope attached to the levers and operate from a safer angle.
roughcut - Looks like you're running the same thing as a Farmi. Correct?
/ PTO winch #13
I have owned a Farmi winch for over 25 years. I purchased the smallest one brand new for $950.00, I wouldn't take that for it now. It is by far the most useful tractor tool, well second to the FEL.
If you can find a used one don't be afraid to purchase it there is not much to go wrong with them. As far a operating it from the tractor seat it can be done. One thing you want to make real sure of, that you pull in a straight line behind the tractor.
You can put a lot of side stress on the 3PH arms and even bend or brake them if you are not careful, as they say don't ask me how I know.
The winch is a great counter weight for the FEL aslo.
Randy
/ PTO winch
Thanks Pete
I looked over the site attached to your post about Vermont (http://www.gatewaytovermont.com/). I would not mind visiting Vermont. What is your affiliation with the web site you sent? Where do you live in Vermont?
Sherpa
/ PTO winch #15
</font><font color="blue" class="small">( Thanks Pete
Sherpa )</font>
Thanks! My wife is the Webmaster of that site, and especially in the early days when I was new to Vermont I was her favorite comic topic! /forums/images/graemlins/crazy.gif She divides her time pretty evenly between tourism and small farming. We live in the tiny town of Mansfield (pop 7) near Stowe. One hill over from the Trapp Family Lodge of The Sound of Music fame.
If you visit, I'll even let you use my winch to harvest next winter's firewood! Such a deal! /forums/images/graemlins/grin.gif
Pete
/ PTO winch
You live in a town about the size of ours, we have about 10 people living around here. It would take the EMS or police about 45 minutes to get here if we ever needed them. I looked on the map, you are 1,000 miles from here. Thats a long way to go to play with a winch but it would be fun. I will have to think about coming up there. How many acres do you have? I only have 5.5 acres to play on but the government land around me is better than 100,000 acres. This is the Pisgah Nat Forest I am talking about. They dont like my tractor or ATV on their land.
Sherpa
/ PTO winch #17
Yeah, that's a bit of a drive. We live right next to a tourist town of 3000 with police and fire/rescue resources for 50,000. It's nice having them close by if we need them!
We have a total of 155 acres, but only about six is flat (well, more or less flat) and clear. The rest is hardwood forest on a hillside that gets pretty steep in places. So the winch gets a lot of use, especially this time of year when it's possible to see the damaged trees without all those leaves in the way.
Take care, Pete
/ PTO winch #18
</font><font color="blue" class="small">( I have a Farmi. Yea, the controls will allow operation from the seat. Safety tells me to do otherwise... Having 100+ feet of cable out there in a line directly behind my seat generates too much pucker for me. )</font>
I offroad in a Jeep quite a bit. One of the safety rules when using a winch is to throw a blanket, coat, or something of that nature over the winch line. In case the line breaks or something breaks loose the weight of the blanket will drop the winch line to the ground. There is no way I would ever operate a winch while being directly in line with the cable.
Bill Tolle
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
250 GALLON FUEL TANK W/HAND PUMP (A62131)
250 GALLON FUEL...
2014 Infiniti QX60 SUV (A61569)
2014 Infiniti QX60...
30 Yard Dumper (A61166)
30 Yard Dumper...
2021 FREIGHTLINER M2 106 S/A 4X2 24FT BOX TRUCK (A59909)
2021 FREIGHTLINER...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
