pto will not spin
   / pto will not spin #1
horhay
Fort Morgan
ford 800
I have a ford 800 tractor 1957 vintage. I recently broke the PTO out put shaft and replaced with a new shaft and bearing assembly it is a the 1 3/8 version. I installed but when I engage the PTO with the lever the shaft does not spin. The shift lever feels normal between engage and dis-engage. Can someone tell me why is does not spin under power? Thanks novice tractor owner.
   / pto will not spin #2
Welcome to TractorByNet!
We moved your thread to the Ford Vintage Tractors forum. :)
   / pto will not spin #3
explain a lil more about the previous damage.
when you said you 'broke' the pto shaft.
what actually happened.
did the stub shaft sticking out break off or?
next.
are you sure the pto engage lever is moving the small arm inside? ( take cover off to verify )
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2017 Dodge Journey SUV (A51694)
2017 Dodge Journey...
2006 Ford Explorer 4x4 SUV (A51694)
2006 Ford Explorer...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
