pto will not engage ls xr4145hc 26 hours
   / pto will not engage ls xr4145hc 26 hours #11
:horseshoe: Good Luck.
Well that did not work. I ran wires from battery to solenoid it kicked on for a second and died I will call dealer monday
   / pto will not engage ls xr4145hc 26 hours #13
Did any fuse blow?
   / pto will not engage ls xr4145hc 26 hours #14
Here are photos of the pto valve that I replaced. Apparently the loose fit of the solenoid on the shaft allows dirt or other debris in and this is the result. Does anyone know how snug the retaining bolt should be behind the solenoid. IMG_2132.JPGIMG_2133.JPG
Only evidence of a short in the solenoid was a small bump on the plastic cover.
The replacement valve shank is smooth and shinny.
FYI, when you order the new solenoid, it comes with a new valve. $140ish as I recall.
   / pto will not engage ls xr4145hc 26 hours #15
Is this a common way now to engage tractor pto's, wires, solenoids and fuses, dont sound like a good way to me, I prefer levers with direct engagement. If I blew a fuse engaging the pto, I'd probably blow a fuse to, good luck with the problem.
   / pto will not engage ls xr4145hc 26 hours #16
Common? Yes. and generally reliable - at least on your main brand colours - Red, Orange, Yellow, Green, Blue. Not sure about Purple...
   / pto will not engage ls xr4145hc 26 hours #18
Here are photos of the pto valve that I replaced. Apparently the loose fit of the solenoid on the shaft allows dirt or other debris in and this is the result. Does anyone know how snug the retaining bolt should be behind the solenoid. It should be a nut, not a bolt - Finger tight plus 1/6th of a turn. Not very tight at all really.
Only evidence of a short in the solenoid was a small bump on the plastic cover. That's evidence of 'melting' on the inside.
FYI, when you order the new solenoid, it comes with a new valve. $140ish as I recall. Seems reasonably inexpensive for both as a combo.
Some thoughts above in red.
   / pto will not engage ls xr4145hc 26 hours #19
No there was none in. I sent power straight to solenoid it engaged then stoped
The implication is that you have two faults.
1.A fuse blows in the loom when the solenoid isn't even connected.
And
2.The solenoid won't maintain the 'pull' when it's fed direct power anyway. (Or the valve is not actuating).
Even if you replace the solenoid/valve combo as Danger did, you will still have a short-circuit in the loom to find.
27 hours. The dealer can deal with it
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
LOT: Fuel Transfer Tank, Tool Box (NO PUMP) (A59076)
LOT: Fuel Transfer...
New/Unused CFG Industrial QH12R Mini Excavator (A57453)
New/Unused CFG...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
2019 DODGE RAM 3500 (A58214)
2019 DODGE RAM...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
