PTO Trouble
/ PTO Trouble #1
badapple
north west lower michigan
John Deere 4310 E Hydro
I have a 2003 deere 4310 Problem is that part in the owners manual where it tells you to always engage the mid PTO before the rear .Well it took 6 years but i obviously wasn't paying attention and did it backwards there was this loud screach then the PTO just quit ....Question IS how bad did I hurt it and how much will it cost to fix???
/ PTO Trouble #2
Ouch!
The mid-PTO is driven from gears on the rear PTO shaft, That is why you must engage the front first so the gears aren't spinning. I suspect at least one gear is stripped of it's teeth...and they are in the sump now. I would not the tractors till it's fixed because the loose teeth could cause a lot more damage. There is no way of knowing until at least the rear cover plate is pulled.
/ PTO Trouble #3
Well, it depends. You will not have to split the case, I know that for a fact. If you are handy, pop the back cover off, and see what you did. The only problem with that is that you will have to drain all the fluids. You can check out my previous post with my 4310 PTO problem if you wild like, also, there is another member on here that rebuilt his entire 4300 from the ground up with excellent pictures Feel free to ask me any questions. I have some for you.
1. Is yours an HST?
2. Does the rear PTO work, and just not the Mid?
I also have the shop manual, so I will help you out if I can.
/ PTO Trouble #4
Also, wonder how badapple came out with his PTO problem. ??
/ PTO Trouble #5
seems like their should be a failsafe on this. it's asking alot for consumers to ALWAYS remember to engage in ONLY one SPECIFIC order. and if you DO forget and do it backwards, just ONCE, CATASTROPHIC FAILURE!!!!
/ PTO Trouble #6
That is one JD design I have never been able to understand why it was done. They really dropped the ball (or gear) on that one.
/ PTO Trouble #7
That sucks.
On my 4720 with EPTO it mentions something like that also but specifically about the front/rear selector lever. It's kind of odd on the EPTO, the selector is for Rear, and Front and Rear, no front only. If you want front Only the EPTO 'shift' at the rear has a neutral to disconnect the rear. Strange.
/ PTO Trouble #8
That is the other odd thing about the 4000 TEN PTO. Since the Mid-PTO cannot be activated without also activating the Rear-PTO, guess you have to remove anything from the Rear-PTO you do not want to be running at the same time.
/ PTO Trouble #9
my 4300 is the same. rear or both. not that i would do it, but i had the brilliant idea of a front AND rear mount snowblower....i suppose as long as you aren't loading both implements at the same time, it would work?
/ PTO Trouble #10
I suspect there is room for one clutch (barely) and not for two....and the cost for one is a factor as well.
But doesn't bode well for the occasional user who doesn't understand the clutch is needed to shift the mid PTO into action. :(
How soon we forget what it was like when a clutch was needed to put the tractor into gear, or we'd grind the gears if we didn't use the clutch :D Same deal with the mid PTO.
/ PTO Trouble #11
my only thought is that there could be some sort of physical 'stop' to prevent the mid pto lever from being engaged if the rear is already engaged. that shouldn't be impossible, or too much to ask.
/ PTO Trouble #12
There is no lever to move. It is electric buttons. The lockout could be done with diodes and a latching relay to only allow the proper sequence.
/ PTO Trouble #13
i lost track of the original poster's tractor/setup...i was referring to my mechanically engaged pto when i mentioned a stop.
but yea, if it's electronic, would probably be even easier to prevent the mid from engaging when the rear is running...until the electronics fail!
/ PTO Trouble #14
Only on the 4x10 series. The 4x00 is levers-I helped WayneH add the Mid-PTO to his 4400 tractor, you really want to pull up the mid-PTO lever BEFORE engaging the rear!
/ PTO Trouble #15
BadApple has not been back... he left after 6 minutes since there were no replies... :p
Kubota Blade (A64126)
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2022 EZ-GO ELITE...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
