Pto Tiller choices
   / Pto Tiller choices #1
ehcrain
Dinwiddie VA
kubota l3901 and massey ferguson 50
Looking to purchase a 5' or 6' pto tiller to go with my l3901. Use would start with breaking ground for food plots and maintaining a garden in the future. Soil type is loam with few rocks of any size larger than a golf ball.
Would you go 6' or 5'? Any brands that you can recommend to avoid or have great experience with?
   / Pto Tiller choices #2
Rototillers with forward rotating tines require little power to operate.
Buy six foot width.
Land Pride makes high quality tillers.
   / Pto Tiller choices #3
I run a 5ft King Kutter behind my Kubota bx 25d - plenty of power even in my rocky New England soil. The thing is a tank- thick steel throughout, hard to imagine damaging it.
   / Pto Tiller choices #4
I use a 4 foot Tar River behind a John Deere X585 and it performs well. Very solid gear drive tiller.
   / Pto Tiller choices #5
A friend has a 6' Tartar (sold by TSC). Only failure has been gear box seals. He replaced and put in "corn head" grease.
When putting in the new input shaft seal, he found a snap ring broken (poor design in my opinion). He said it must have been his fault for operating with the PTO shaft too long, putting pressure on the snap ring.
   / Pto Tiller choices #6
I have owned King Cutter implements.
I have shopped Tractor Supply's CountyLine/Tarter implements many times. In the last eight years have only purchased a Tarter Boom Pole and a mat Chain Harrow from TSC.
I my opinion King Kutter implements are several increments higher quality than Tarter implements.
   / Pto Tiller choices #7
I use a standard 5' KK tiller in nice rockless soil. I have taken off the shoes so it can go deep. No problems and I would buy again.
   / Pto Tiller choices #8
If your food plots are in wooded areas, let the width of your access points, turns especially determine your width. For every 6” wider on each side, your space to turn especially tight turns increases quite a bit.
If this is a non issue, I would go with wider (6’) as you will enjoy the time difference to get the job complete quicker with an additional foot tilled with each pass.
I would never suggest narrower that the tread width of your rear tires.
   / Pto Tiller choices #9
I got a Terra force ER062 from a local dealer a few months ago, haven't had a chance to really use it, just a short test patch in the yard once I cut the PTO to length (I plan to excavate there for a slab soon). From my research, they seem to be well regarded and it's also a brand sold by EA, so I figure they must be pretty good for EA to sell them.
Currently thinking about this unit from agrisupply, they are local to me and i know that parts should be available through them.
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
