Pto stuck on
   / Pto stuck on #1
plum creek tech
Carmel, Indiana
new holland TC33D, John Deere 955
I replaced the counter shaft and drive gear. They were toast ! Put it all back together and the pto lever is in the on position and won’t move. The pto shaft is free and turns. I guess I should have put the levers on and worked it before I assembled it ? TC33D
   / Pto stuck on
I have not recieved any responses on my thread, but i have solved the problem. I disconnected the pto lever from the linkage going into the bottom of the gear box. I then removed the half pin that holds the shaft in the gear box. I put a pair of vice grips on the shaft so i can rotate it. very carefully i started to pull out the shaft while rotating counter clock wise. it broke loose. popped out to the proper detent and voila ! Its good !
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A57880)
2019 TOYOTA...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
True 750E Elliptical (A54816)
True 750E...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A56857)
2015 Vermeer SC362...
PENDING SELLER CONFIRMATIONS (A57880)
PENDING SELLER...
