Pto stuck on
   / Pto stuck on #1
plum creek tech
Carmel, Indiana
new holland TC33D, John Deere 955
I replaced the counter shaft and drive gear. They were toast ! Put it all back together and the pto lever is in the on position and won’t move. The pto shaft is free and turns. I guess I should have put the levers on and worked it before I assembled it ? TC33D
   / Pto stuck on
I have not recieved any responses on my thread, but i have solved the problem. I disconnected the pto lever from the linkage going into the bottom of the gear box. I then removed the half pin that holds the shaft in the gear box. I put a pair of vice grips on the shaft so i can rotate it. very carefully i started to pull out the shaft while rotating counter clock wise. it broke loose. popped out to the proper detent and voila ! Its good !
2010 Wacker Neuson Light Tower (RUNS) (A50774)
2010 Wacker Neuson...
2018 Bobcat T870 Skidloader (RIDE AND DRIVE) (A50774)
2018 Bobcat T870...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
John Deere 3038E (A50120)
John Deere 3038E...
2016 Volvo 82041 9.5 Cu Yd Hydraulic Loader Bucket (A50322)
2016 Volvo 82041...
2023 Cat 310 Excavator (RIDE AND DRIVE) (A50774)
2023 Cat 310...
