PTO step up: 540 to 3600 RPM
   / PTO step up: 540 to 3600 RPM #1
davel8257
odon, IN
Kioti DS4510HS
Generators, power washers, car alternators, hydraulic pumps, air compressors typically do not operate at 540 RPM -- they are designed to attach to a 4-cycle engine. I'd like to build a multi-purpose, 3pt platform with a step-up system that provides a 4-bolt interface and an output shaft turning at around 3000 - 3600 RPM.
I think I'd choose belt drive (for some 'give'). I think I'd choose a 1:10 ratio -- my Kioti's PTO hits 540 RPM at 2500 RPM (engine tach). I'd rather 'idle' down to around 1500 RPM, consume less fuel, less noise (& less power -- all I want is 'lawn mower' engine output). At 1500 RPM, the PTO is turning around 300 RPM (5:1 ratio). I'd want to step the 300 RPM up to 3,000 RPM or so. A 1:10 ratio step-up (like a 12" pulley driving into a 2" pulley). Pillow block bearings, 1" shaft stock, milled key-ways....
Has anyone tried something like this?
I've seen posts that comment on fuel consumption (higher on a 45 HP tractor than a 5HP lawn mower engine), etc... but I think I'd rather not have the extra engine sitting around requiring maintenance, not starting when you need it, etc...
   / PTO step up: 540 to 3600 RPM #2
Do it in two hitches, that is a 3:1 and then a 3.3:1. With some engine-uity the shafts can run concentric.
Had a pull behind snow blower done up that way. Chain drive... the drive worked fine, the blower...? Not so well ;-)
   / PTO step up: 540 to 3600 RPM #3
If all you really want is lawn mower engine output, you could use step down pulleys like they have on large drill presses and other shop machinery. That would give you a wide range of output rpms in case you run into some other requirement down the road.
That's a good idea. I like the idea doing two stages. Still not seeing the time in my schedule to work on it yet...:(
   / PTO step up: 540 to 3600 RPM #5
How much are you trying to save? If this equipment is running 24/7 then sure the investment will eventually pay off. For a few dozen or even a few hundred hours a year. The pto and stepup drive is a curiosity and hobby project rather than being practical.
eBay lists 540 to 1800 gear boxes. Odds are the same manufacture makes 540 to 3600.
Safety is another factor as 99% of these projects have exposed whirling belts, pulleys and shafts that are obvious and nobody should get maimed or killed with. Yet hospital ERs do a brisk business with mangled and missing limbs.
   / PTO step up: 540 to 3600 RPM #6
I was just thinking of all those noisy low end pto powered standby generators with a 540/3600 gearbox. Could probably find a used generator , remove the gearbox and sell the gen head to somebody wanting to direct couple it to a 3600rpm small engine.
Odds are that would be cheaper than the parts alone to cobble together a 1 to 8 drive.
   / PTO step up: 540 to 3600 RPM #7
PTO turns opposite direction of engine, does that matter to you?
   / PTO step up: 540 to 3600 RPM #10
Stay away from small pulleys. A 2" is hard on belts and has a lot of loss as you are only contacting a small segment of the circle. Start with at least a 4" on the higher speed shaft and work up. hat is where a 2 step arrangement pays off on keeping the profile down. In all not very practical. Look in the Surplus Center Catalog on page 71; they have a hyd motor that does 3000 RPM for $178-$220 depending on HP output. I doubt you cold gather all the materials for your pulley arrangement for that.
Ron
20711 (A50323)
20711 (A50323)
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
2020 Mesa Ridge Lite 2802BH 32ft Travel Trailer (A52377)
2020 Mesa Ridge...
90018 (A48082)
90018 (A48082)
TEST YOUR BID BUTTON! (A54757)
TEST YOUR BID...
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
