PTO sprayers (2 questions)
   / PTO sprayers (2 questions) #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have recently decided to purchase a PTO operated sprayer. I have enrolled some of my land in a TPWD native grass restoration program. It calls for spraying improved pasture to kill out the bermuda and bahia grass so that native grass can be planted this fall. I am putting in 25 acres this year and may do so each year for the next several years. I also have the occasional need to spray fencerows etc. I will need the sprayer to have a spray wand as well as fold out booms. I have never used a sprayer before. I will be using a Ford 7710 or a NH TB110. Here are my questions:
1) trailer or 3 pt. (what tank capacity)??
2) what are some good brands (USA only please)??
   / PTO sprayers (2 questions) #2
How big is your tractor? The bigger the tank the better. It is not at all uncommon to use 20 gallons of spray per acre to get adequate coverage. 25 acres = 500 gallons which equals 4000+ lbs. I had a 125 gallon tank and it was ok but I did several jobs where I had to refill and remix.
I don't know what brands or if it even mattters. just check out what they have at Tractor supply or wherever. What you are doing is low volume compared to the high use pumps that get used for hundreds or thousands of acres. In other words the cheapest one should work fine.
   / PTO sprayers (2 questions) #3
We have several small fields in 10-30 acre size range that we converted and maintain in NWSG mixes, and continue to convert other pastures. Based on our experience, here are a few other things to consider:
1- If using glyphosate, make sure your pump will stand up to its corrosive nature
2- booms are fine on flat land, and where you don't have to negotiate fencerows and gates. We're hilly, with lots of fencerows, so we ditched the booms and went with a high volume boomless nozzle from TeeJet. You can block the orifices on it to spray just about any direction. The drawback is that the day must be windless.
3- Anything particularly maneuverable is going to be fairly small and require frequently fill-ups, so consider your access to a good water source
4- A hose and gun is a handy addition to the system
We settled on a 3-pt system, 125-gallon tank, corrosion resistant Hypro roller pump, and the boomless nozzle I mentioned before. It's worked well with glyphosate, 2,4-D, and imazapic. Your tractors could handle a larger tank, given some front weight.
For the two chemical burndowns you are likely to do prior to seeding a field, save yourself some trouble and time by having the local co-op bring a dedicated sprayer.
   / PTO sprayers (2 questions) #4
I have a 55 gallon Fimco 3 point for my 45HP tractor and a 25 gallon spot sprayer for the back of my Kawasaki Utility vehicle. I also went with a boomless nozzle as I thought it would be less susceptible to collision damage.
I do fencelines with the spot sprayer as I do not want to have a lot of overspray for the neighboring cops.
For a main sprayer 25 acres would be a few refills with a 55 gallon tank to put the several gallons of liquid an acre that the herbicide manufacturers all seem to recomend for effectiveness. I went with that size due to cost and size considerations. Bigger would be better if you can swing it.
   / PTO sprayers (2 questions) #5
Personnaly, I'd go with 12 v pumps (about $100 each) instead of the PTO pumps. Over the years, I've found the 12 v pumps easier to maintain (and cheaper to replace, if needed). Big farm spray rigs seem to use the 12 v pumps as well. Might be worth checking it out for your needs.
And for fence row, I have a boom with nozzles that can be configured to spray individually, making the outside nozzle (or two) useful for spraying strips along fencerows (where accessible). I use the wand for spot spraying thistles.
   / PTO sprayers (2 questions) #6
I made the mistake of buying a FIMCO sprayer. I'm still waiting. Horse**** service.
Never again.
-Mike Scheer-
   / PTO sprayers (2 questions) #7
I just built my own out of a 15-20 gallon tank. I used a 12 volt pump instead of a roller pump just for the simple fact that the roller pto pumps put out 100psi at 1000 rpm which was to much for me. I think im gonna have to do some work on making a refief valve setup for mine to start to by pass at 35 psi though so that the pump runs constant instead of kicking on and off. I currently have mine rigged up with a bypass valve pinched back to keep 35 psi constant.
   / PTO sprayers (2 questions) #8
Demco (usa) has a nice lineup, i own one myself with a hypro 6 spline pto pump.
   / PTO sprayers (2 questions) #9
Here are the pictures of the 125 gallon pto rig I made. It had folding booms and a electric switch to turn the spray off and on. It also had a return / agitator with good volume to help keep the tank mixed. It would take a pretty serious 12v pump to get the job done.
   / PTO sprayers (2 questions) #10
I'm in the process of making a 125 gallon sprayer to replace a smaller gas driven unit. Considered buying a pto unit but decided on 12V because of flexibility of using either my tractor or RTV. Am using 2 pumps for wider boom coverage. 2.1 gallon units are cheap and switchs allow me to vary width. This is important because some of my spraying is between rows of planted trees. Plumbing is pretty straight forward for construction. Only spraying herbicides; primarily glysophate so no high pressure or wettable powder considerations.
   / PTO sprayers (2 questions) #11
I have Fimco 60 gal 3 point with a Hypro pto pump and am very happy with it so far. I run the tractor at about 1400 rpm and adjust the valve to about 20-25 psi. It has an internal bypass so the solution stays mixed and a 10' boom and 25' hand sprayer. My only complaint so far is the paint on the frame and boom uses no primer and it fell off pretty quick.
   / PTO sprayers (2 questions) #12
I bought a 3 point 110 gal boomless one recently that was made by Schaben Industries. I haven't used it much yet but am impressed so far. They have a plant in Newton, KS which is close to Wichita. I ordered mine through a JD dealer but I think you can also buy direct from Schaben.
   / PTO sprayers (2 questions) #13
   / PTO sprayers (2 questions) #14
I purchased a 55 Gal hand wand unit from these folks and have been happy.
Ag Spray Equipment - Farm, Lawn, Garden, Spot Sprayers, Parts, Pumps, and Tanks
I custom made a dual 55 gal pto pump operated unit
http://www.tractorbynet.com/forums/attachments/143121-re-build-spray-rig.html
Welcome to The Accuspray Emporium were Smiles are Free was a good source for parts of all types needed to put it together - very helpful folks.
   / PTO sprayers (2 questions) #15
Thanks for all the good info guys! This is one of my next projects so I am listening carefully.
   / PTO sprayers (2 questions) #16
Sounds like the pasture spraying is a one-time preparation spray for the planting of each field, and no maintenance sprays. If that's the case you might consider hiring that out.
Then purchase like a 50-100 gallon 3 pt sprayer with a wand for the fence rows, or even hire that out too if it's so infrequent.
Something to consider.
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A59230)
2004 Pierce Tilt...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2018 FREIGHTLINER...
FORD 545D TRACTOR (A60430)
FORD 545D TRACTOR...
32in. Tilting Bucket Mini Excavator Attachment (A59228)
32in. Tilting...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
