PTO Speed
   / PTO Speed #1
sirgknight
South Georgia
Early model YM1700
The 1700 has three pto positions: 1-2-&3. Which position is which speed? I've been running all of my equipment in position two, which is where the dealer placed the lever, but I'm thinking that position 2 is 748 rpm. Isn't position #1 for 540 rpm?
   / PTO Speed #2
On my FX24D positon 1 is for 540. Mine has a tach which shows BOTH engine & PTO speeds; therefore, I know that you can have 540 in any position depending on engine speed. Ofcourse, the difference is how much power the PTO has.
   / PTO Speed #3
Not absolutely sure, but I believe it's 588 - 730 - 1260 @ 2200 RPM. And yes the first position is lowest for approx 540 rpm pto speed. Mark
   / PTO Speed #4
I have a 1500...and don't have my manual in front of me...but here it goes anyway.
I believe your 3 positions are as follows. 1 is for 540 PTO RPM at "full" engine speed. 2 is for 1000 PTO RPM at full engine speed. And 3 is the same as engine speed---so if your engine is at 2000 RPM so is your PTO in the "3" position. Almost all USA rear PTO/three-point implements are to be used at 540 RPM only. Running your brush hog or US rototiller at 100 RPM could do damage to people and equipment. Many mid-mount mowers may run off a mid PTO at 1000 though.
Hope this helps and I hope I did not get the numbers in backwards order!!??!....simply looking at the PTO whould tell you which postion it runs slowest at (540).
Peter
   / PTO Speed #5
As far as I know.. 1 is 540 or close.. 2 is 768 or 7xx.. and 3 is 10xx
Soundguy
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
GENERAC GP6500 GENERATOR (A50854)
GENERAC GP6500...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
