PTO slipper clutch add-on?
   / PTO slipper clutch add-on? #1
eflyersteve
Somewhere, OK
Mahindra 1533
I have a 5' rough cutter with shear bolt type PTO safety. I'm getting tired of replacing bolts and see that there are add-on slip clutch adapters available. Would this be the best route to go or would it be better to just buy a slipper clutch PTO shaft? Any recommended products?
For those that ask the obvious question: "why are you hitting stuff to shear the bolt", I say to you: I don't know why. The area that I cut has some small hills and dips and it seems just scalping the ground will shear off a bolt. Dealer recommended replacing the grade 3 bolt with a grade 5 (but specifically said no grade 8), but I'm a little hesitant. Maybe that is common practice and something I should follow?
Thanks!
   / PTO slipper clutch add-on? #2
When I bought a tractor years ago one of those add on slip clutches came with it so I have used it with other tractors. The only problem there isn't any info on it for H.P. rating that I can see . I have never sheared a bolt on my bush hog so it must be working .
Case Ih 1660 Combine (A50514)
Case Ih 1660...
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
Barn Wood Bar Table (A50515)
Barn Wood Bar...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
RSC 45" ELECTRIC LIFT (A50322)
RSC 45" ELECTRIC...
Cat TH407C Telehandler (A52748)
Cat TH407C...
