pto slip clutch
   / pto slip clutch #1
Bedlam
Does anyone have any good sites that sell a PTO SLIP CLUTCH.?
I have a brush hog and cordwoodsaw, that Id like to have 'protected' .
I see the 'overrunning" ones but I seem to remember seeing ones that go on the shaft and would slip if you hit something.
I have found this one. In the slip clutch section. Has anyone seen these or have any experience with them?
http://www.ssbtractor.com/page41.html
Thanks.
Al
   / pto slip clutch #2
Have you tried Agri-Supply.com?
   / pto slip clutch #4
That one looks to be splined Allan, make sure the implement end of a slip clutch is compatible with the input shaft of the implement. Some input shafts are round, some are splined. If you're not sure, the bottom of that AgriSupply slip clutch is the implement end. I'm pretty sure it's splined. http://www.ptoshafts.com/newpage31.htm has a very good selection of both splined and shear pin (round) styles.
//greg//
   / pto slip clutch #5
I got a one for a #4 metric for my 60" tiller. It's great was a good price too. The suggestion about making sure of the implement end is a good one. The people at Agri-Supply are helpful too. bjr
   / pto slip clutch #6
Good advise, check it out and avoid a mistake.
   / pto slip clutch
Thanks for the reply.
with reference to http://www.agrisupplyco.com/cgi-bin/cgiitmls?m=ThisP&p=31951.000000&l=1
I thought that the bottom part was female and slipped over the male pto shaft that is on the tractor. And the top end in the pic is female and would except the female implement coupler.(basically in-line).
Does that seem to be right?
I understand the 'smooth" shaft one is for a pin.
Thanks again
Al
   / pto slip clutch #8
Nope. The slip clutch always goes on the implement end. Too dangerous to have those exposed springs so close to the operator. Overrunning clutches (generally) go on the tractor end, slip clutches belong on the implement end.
//greg//
   / pto slip clutch #9
Bedlam
The slip clutch is mounted at the implement end of the shaft. The tractor end is unchanged. I recently added a slip clutch to my Bush Hog rotary cutter.
The model I have has a smooth shaft on the gear box which was shorter than the clutch was designed for. I had to machine about 1/4" off of the female hub to allow the shaft and hub bolt holes line up plus drill out the hole in the mower shaft to accept a larger bolt. I mention this to warn that adding the slip clutch may not be a simple bolt up job as I had expected it to be.
Vernon
   / pto slip clutch #10
Thanks.
Al
Try
http://www.agpartz.com/agcat/index.php?cPath=33&osCsid=90a54b3c4aafa5a8007df4264846b615
I recently bought a Weasler slip clutch from them for about $100 including shipping.
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
Portable Restroom (A54865)
Portable Restroom...
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
Year: 2010 Make: Toyota Model: Prius Vehicle Type: Passenger Car Mileage: 62,669 Plate: Body Type... (A55758)
Year: 2010 Make...
