pto slip clutch
/ pto slip clutch #1
ColdRider
Northern Maine
1985 B7200 Hst/ fel(sold) 2011 L3800 Hst/ fel
Does anyone know where I can find a 2 plate slip clutch, 5" in diameter with a standard 1 3/8-6 spline? Either m/f shaft or f/ yoke. Thanks.
/ pto slip clutch
Thanks Jerry, but no luck. I have exhausted about every tractor parts supplier I could find . They all seem to carry the same parts. All too big. The smallest I've found was 6" and it just won't fit in my space. I may have to get out the welder and make it direct drive!;)
/ pto slip clutch #4
Smallest diameter slip clutch I know of is the Walterscheid radial pin clutch. We used them on each row unit on our Gleaner corn heads, but they normally are fit in drivelines that need smaller diameter and less maintenance than friction disk clutches although they do ratchet rather giving pulsating torque at slip rather than a peak torque at slip followed by lower torque once the friction disks change from static to dynamic friction. Here is a link to a source so you can see what they look like.
Radial Pin Clutches
/ pto slip clutch
I just want to thank everyone and let you know I fixed the clutch. I found a close match to the clutch discs (inside almost exactly right and outside a bit big) on-line and made them fit. I've been tilling and it's working ok so far.
Thanksagain, CR
HYSTER H80XM STRAIGHT MAST FORKLIFT (A64279)
HYSTER H80XM...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
APPROX(15) DIAMOND PATTERN PLASTIC PROTECTION MATS (A64281)
APPROX(15) DIAMOND...
2025 70in Rock Bucket Skid Steer Attachment (A61572)
2025 70in Rock...
20ft trailer (A61569)
John Deere Starfire 3000 (A64119)
John Deere...
