PTO shifter on BX2200
/ PTO shifter on BX2200 #1
Anonymous Poster
Epic Contributor
Is your PTO select lever hard to shift? Mine is very difficult to move between settings. I have to keep engaging the PTO while moving the Select lever or it wont shift at all. When I do that I can hear the grears grind. Doesn't seem right to me.
Is there any trick to this? Do you think there is something wrong with my linkage or adjustments?
John
/ PTO shifter on BX2200 #2
John,
Mine did the same till about 90-100 hours on the tractor, plus a entire winter of snow blowing with the 3 pt snowblower, it is now very easy to move, no grinding, works great. Give it time to wear in and it will be ok, /forums/images/graemlins/wink.gif
/ PTO shifter on BX2200 #3
the PTO lever on my 2200 was very hard to shift because of the plastic stops molded into the indicator panel on the tractor. Seems as if there was a middle detent position that served no purpose. I am as committed to safety as anyone else but after a few frustrating hours of using the mmm I filed down the little plastic stops. The lever moves very smoothly and there is no noise now.
There should be no gear noise as the hydraulic system does the shifting. Are you engaging the pto at slow speeds? Maybe it is the mower or 3pth attachment.....
/ PTO shifter on BX2200 #4
Those stops ended up tearing the plastic off the lever on my BX.. I keep thinking of filing them down or cutting them off... interesting that I'm not alone in that thought.
Mine is still tough to shift at 150 hours, a little gear grinding is usually in order.
- Patrick
/ PTO shifter on BX2200 #5
Try a little spray lube, like WD40 on the linkage on the side of the trans. Mine was balky and after spraying it is as smooth as silk.
paul
Thanks for all of the suggestions. I will try all of them, one at a time, starting with the lube. The lube sounds like the easiest fix and I have lots of WD40 and spray white lithium grease.
I will let you know how I make out.
John
I had a problem with the hst range selector being balky after I washed the bx. Finally sprayed super lube on the linkage (tough to get a can in there) and voila!, everything is smooth again.
DaveL
The lube did the trick!
I could only find one place to squirt WD40 for the PTO selector. It looks like there may be some paint in the pivot joint. Sure works a lot smoother now. I lubed the other linkages while I was at it. They all work better now.
All.... Thanks for the info.
John
</font><font color="blue" class="small">( I had a problem with the hst range selector being balky )</font>
My 4WD shifter is much harder to shift then I think it should be. Has been since new. You have to really work at it to shift it in and out. No grinding, and it works fine, just hard to shift. Are they all like that or should I look for a problem? The lever seems to move smoothly enough. It is the in-to or out-of part that is difficult.
/ PTO shifter on BX2200 #10
David:
The manual kind of makes reference to the balky 4wd engagement when they say that if you can't engage the lever then step briefly on the hst pedal and then try the lever again.
I have found that both the 4wd and the low/high range levers are a bit balky and that by tapping the hst pedal and allowing it to return to nuetral they then will go into the proper engagement.
Guess it is the nature of the beast
/ PTO shifter on BX2200 #11
I just rock my whole 2200 with my body (by rocking back and forth) while i try to shift my 4WD or my PTO selection leaver
or even shifting from low or high range it all goes a little smoother this way.
/ PTO shifter on BX2200 #12
</font><font color="blue" class="small">( I just rock my whole 2200 with my body (by rocking back and forth) while i try to shift my 4WD or my PTO selection leaver
or even shifting from low or high range it all goes a little smoother this way. )</font>
I'll bet your neighbors get a kick out of that one /forums/images/graemlins/grin.gif
/ PTO shifter on BX2200 #13
There have been several threads on this subject. It is not a matter of WD40--unless you really do have a tight or sticky lever--and I would not use WD40--but anyway--the problem is that the gears are not synchromesh. If the gears stop with a tooth in alignment with another tooth it does not want to engage. This is why rocking the tractor helps. I have--with the tractor engine shut off--reached under and grabbed the PTO shaft and rotated it to another position. Time will help the gears "loosen" up for lack of a better tern (drinking Margarittas right now--brain slow). Bumping the hydro lever might also help. My 2410 does the same thing but it has a manual clutch and also bumping the hydro helps with it also. In any case no matter how long you own the tractor or how many hours on it there will be times the non syncro gears stop adjacent to one another and it will not shift without a little fiddling with it. J
10222 (A56858)
10222 (A56858)
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2014 Ford Explorer SUV (A61569)
2014 Ford Explorer...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2016 CATERPILLAR 930M WHEEL LOADER (A62129)
2016 CATERPILLAR...
