Cottonhawk said:
Any suggestions to make the PTO shaft glide smoothly? I tried to keep them greased but some of my PTO shafts glide fine and some get stuck often. None of my PTO shaft glide as smooth as I would like to see. How about hit the inside shaft surface with sand paper? Pros and cons? Will it cause the shaft surface to rust and stuck worse?
PTO Shaft - Every 20 hours
Disconnect PTOshaft from the tractor and slide apart. Clean
and coat the inner tube of the PTO shaft with a light film of
grease and then reassemble.
Type of Lubrication: Multipurpose
Quantity = Light Film
General stuff you already know...but maybe someone else could benefit from...
PTO shafts can be separated or pulled apart. The two parts are
made so that one part fits into the other. The PTO must be able to
telescope in and out to permit machine operation over irregular
terrain. If the parts become separated, they must be
re-assembled in phase to avoid placing extra strain on the
universal joints. Many shafts are designed to prevent this from
happening.
Check the enclosed for a picture of Phasing...
