PTO Shaft Wont Come Apart
   / PTO Shaft Wont Come Apart #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
Let me preface this that I searched for 15 mins before posting this...
I have a new PTO generator. When I brought it home, I went to take the PTO apart to cut it, but when I fully extend the shaft, it stops abruptly. I can't take is apart.
There is nothing in the shaft manual about this, can I can't pry the shaft cover apart to see if its that.
Any other thoughts?
Thanks in Advance!
   / PTO Shaft Wont Come Apart #3
I've seen older shafts seize, but never a sudden stop on a new shaft. Maybe there is some minor manufacturing defect? Shafts have pretty tight tolerances between the inner and outer shafts.
I agree a quick call to the dealer would be prudent, but I suspect the answer will be to apply some force... Proceed at your own risk, and good luck!
   / PTO Shaft Wont Come Apart #4
If there is a dent anywhere along the outer shaft it may permit the shaft to slide in and out to a point but prevent movement beyond a certain point. If you have the protective sleeve over the shaft you may not see the dent. Without the sleeve it may not be real obvious. By all means contact the dealer if it's a new unit but it could have been damaged in transit somewhere along the line.
   / PTO Shaft Wont Come Apart #5
If new, the dealer might exchange the shaft for a shorter/different one.
Bruce
Thanks all!
   / PTO Shaft Wont Come Apart #7
Is it possible there would be a stop on the shaft so that it doesn't come all the way apart? If there is plastic covering on the shafts, can you uncover it enough to actually see the ends? Set screw?
   / PTO Shaft Wont Come Apart #8
I would not pry or try to force the shaft apart. You could cause damage that might not be covered under warrante.
BY ALL MEANS - contact the dealer.
   / PTO Shaft Wont Come Apart #9
I suppose another way to look at it.
Say you want to cut it a foot shorter.
Then pull it all the way open, and cut your foot out of the middle.
Put it back together and start generating
   / PTO Shaft Wont Come Apart #10
I know it seems obvious but start by greasing it good.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A51572)
2015 International...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
(4) Sumitomo 11.00 R22 Tires (A51573)
(4) Sumitomo 11.00...
