Rear Finish Mower PTO shaft stuck
   / PTO shaft stuck #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
any ideas on freeing up the slide on the pto shaft from the mower
ine is very stuck fromsitting and wont slide,had it hooked and it doesnt want to break free...
   / PTO shaft stuck #2
you've tried a penetrating break-free lube like liquid wrench, master blaster, or wd40 ?
   / PTO shaft stuck #4
throw it in a bucket of diesel for a few days, fil the center too..
capilary action should wich it up betweent he tube halves.
see what that gets you.
soundguy
   / PTO shaft stuck #5
I used PB Blaster a come-a-long and a couple fence posts to free up a shaft that came off an implement that had been sitting out for decades. Keep tension on the shaft and keep spraying with penetrating oil. It took several hours since I would spray and tighten then go off and do something else. Then spray again. Some heat might help also. My friend was able to free up the locking pin on that same shaft with some heat. I had tried a sledge hammer and PB Blaster and it never moved.
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2022 Adams CLC-1013 Conveyor - New (A53472)
2022 Adams...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
