Rear Finish Mower PTO shaft stuck
   / PTO shaft stuck #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
any ideas on freeing up the slide on the pto shaft from the mower
ine is very stuck fromsitting and wont slide,had it hooked and it doesnt want to break free...
   / PTO shaft stuck #2
you've tried a penetrating break-free lube like liquid wrench, master blaster, or wd40 ?
   / PTO shaft stuck #4
throw it in a bucket of diesel for a few days, fil the center too..
capilary action should wich it up betweent he tube halves.
see what that gets you.
soundguy
   / PTO shaft stuck #5
I used PB Blaster a come-a-long and a couple fence posts to free up a shaft that came off an implement that had been sitting out for decades. Keep tension on the shaft and keep spraying with penetrating oil. It took several hours since I would spray and tighten then go off and do something else. Then spray again. Some heat might help also. My friend was able to free up the locking pin on that same shaft with some heat. I had tried a sledge hammer and PB Blaster and it never moved.
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
2013 PHOENIX GLOBAL TANDEM AXLE MANIFOLD TRAILER (A52472)
2013 PHOENIX...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
1998 FORD CRANE (A52472)
1998 FORD CRANE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
