PTO shaft sizes
   / PTO shaft sizes #1
HODAK
NE Pennsylvania
CK30HST
Can someone confirm that the PTO shafts are the same size for CAT I and CAT II? I know the lifting pins are different sizes, but I'm not sure if the shafts are both the standard 1 3/8". Thanks!
   / PTO shaft sizes #2
Modern 540 RPM PTO shafts are the same size. The 1000 RPM PTO shafts on larger tractors are different. Hope this helps.
Lewis
   / PTO shaft sizes #4
The "size" of the splined shafts are standard (nowdays) but those shafts are all available in different HP ratings. A shaft for using on a 100 HP tractor and bush hog combo would be MUCH heavier than what would be common to a 4' finish mower for a 25 HP tractor.
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51691)
2008 Ford F-750...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2007 Deere 650J LGP (A50123)
2007 Deere 650J...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
2024 Kubota BX23S (Dothan, AL) (A50123)
2024 Kubota BX23S...
