PTO shaft size
   / PTO shaft size #1
bones66
Bronze Member
BlueGrass State
MF-230
If the tractor pto has 6 splines and it is a 1 3/8 can I assume the other end of the shaft which fastens to the Bushhog gearbox and has 6 splines is also 1 3/8?
   / PTO shaft size #2
Depends, IF the rotary cutter was made for a 1000 RPM tractor, then NO, also some really old import rotary cutters even turned the opposite direction. (by todays standards)
SR
   / PTO shaft size #3
A lot of them have something like an 1 1/8" keyed shaft.
   / PTO shaft size #5
Easy way to find out: try connecting the tractor end to the implement. If it's proper 6 spline 1 3/8 the detent ball should lock on too.
   / PTO shaft size
SR
I’m possibly wrong but I think 1000 RPM pto shafts have 20 splines (1 3/8) or 21 splines (1 3/4). Thus tractor equipped with both 540 & 1000 outputs cannot be mixed.
..... but I have 6 spline on both ends. Both ends look identical in size but of course the tractor side has the push detent and the implement side although splined has a bolt pinning (Not a shear bolt) it to the Bush Hog. I want to put a slip clutch in-line and was double checking before I ordered. I couldn’t find dimensions on Bush Hogs website.
   / PTO shaft size #7
Pull the PTO shaft and see if the tractor end will fit on the gearbox end. You are trying to run it connected this way, just doing a dirty size check! If it does not fit as tightly as it does on the tractor PTO stub, go buy an inexpensive caliber and measure the gear box shaft diameter. Calibers can be bought most anywhere from harbor freight, Lowes, home depot and on and on.
   / PTO shaft size
Guys I have a caliper but believe it or not I couldn’t find the correct way to measure a PTO shaft.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
20306 (A51694)
20306 (A51694)
1998 Spartan Mountain Master 40FT Class A Motorhome (A50324)
1998 Spartan...
2019 FORD F-250 SUPER DUTY (A52472)
2019 FORD F-250...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
