I finally was able to find a used brush hog, rotary cutter, whatever you want to call it.
I had a hard time finding one that wasnt junk. Anyway, got it home and the u joints aren稚 as good shape as I thought they would be.
I知 debating having someone replace them or just buy a new shaft. The cutter is cureently shear pin not slip clutch and I wouldnt mind switching it over if it isnt too expensive. My other reason for considering buying a new shaft is the plastic sleeve is all busted off the original one.
I知 having a little difficulty knowung which shaft I need. I致e been looking on agrisupply痴 website. Whats the difference between the different series of shafts? Like series 4, 6 etc.
With the cutter hooked up, it measures 48 from the base of pto shaft tractor end to the base of the gear box.
So, is this the shaft that would work?
PTO Shaft - PTO Shafts | Agri Supply 89367
