PTO shaft question
/ PTO shaft question #1
RFB
Platinum Member
None
I have not had the need nor opportunity to use any attachments requiring PTO operation. That is changing pending the arrival of a Loftness 841S snowblower.
I have a few questions regarding the PTO shaft.
PTO shafts that I have seen in photos have telescoping plastic guard sheaths over the rotating inner shaft. There is also a chain attached to the guard. what is the purpose of the chain?
/ PTO shaft question #2
The chain helps keep the plastic guard from rotating while the PTO is in operation. I also use it on my Bush Hog to keep the PTO shaft out of the dirt when it's not in use by wrapping it around the mast cross-member.
thank you sir.
/ PTO shaft question #4
RFB, hook the chain to something on the tractor. Sometimes i run my chain up around the top link and hook it back to itself. Just run the impliment up and down to ensure the chain has a small amount of slack in it, and that it does not bind.
/ PTO shaft question #5
That's good advice (where were you last summer) besure to check it before you run the PTO. Wish I would of thought of that last year before I picked up the bushhog and then the chain broke and yep the little yellow thing turns rather quickly at 540 rpm!
