PTO SHAFT ON 55HP FARMTRAC SNAPPED WHILE USING AUGER
   / PTO SHAFT ON 55HP FARMTRAC SNAPPED WHILE USING AUGER #1
SHERYLDBP
MERCER, PA
55HP FARMTRAC
GOOD MORNING, PLEASE HELP. BOUGHT A 2006 FARMTRAC 55HP TRACTOR. WAS SPLITTING FIREWOOD WITH AN AUGER AND THE PTO SHAFT SNAPPED. DOES ANYONE KNOW IF THE SHAFT CAN BE REPLACED FROM THE REAR OF THE TRACTOR AND HOW MUCH WOULD THE SHAFT COST? BLESSING SDBP:(
   / PTO SHAFT ON 55HP FARMTRAC SNAPPED WHILE USING AUGER #2
I have had mine apart plenty. You could probably remove the lever and pull the fork out. Then pull the 4 bolts from the rear and pull the PTO out. The coupler on the shaft would stay inside. Remove the broken shaft from the cover and replace the shaft and slide the coupler on from the inside. Make sure the PTO slides over the little nub on the transmission output.
http://lib.store.yahoo.net/lib/yhst-97092812362812/parts545-555v3.pdf parts breakdown, shaft is $149 from ITP
Search
Any other questions just ask.
.Thank you so very much for your help Clint S..............Blessings, Sheryl
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52128)
2006 Magnolia Dry...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
