PTO Shaft Needed
/ PTO Shaft Needed #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
Where can I locate a CV shaft for a 15' Bush Hog flex wing cutter? It's the main shaft from the tractor to the splitter gear box.
/ PTO Shaft Needed #2
I am in the same boat after ripping my U joint apart to my post hole digger. I went to my local Kubota dealer and can order a drive shaft. I checked on Tractor Supply company and can order on online from them. The Kubota guy told me to check out our local driveline company which isn't too far from work. So I am going to bring my drive line to them to see what they can do.
/ PTO Shaft Needed #3
I went to my local driveshaft/truck part house and they wanted $300 for a slip clutch I could order from Agri-Supply for $80 a couple of years ago. I get all I can from Agri-Supply now. There's been a couple of things I've had to get from the local Dealers that they Agri-Supply didn't stock, but PTO stuff is good chance they have it. bjr
/ PTO Shaft Needed #4
How long is it when closed and what diameter is the input shaft on the gearbox and the # of splines? Be good to know what metric series is the driveline 5-6-7-8 etc? Ken Sweet
/ PTO Shaft Needed #5
Get ready for a real shock when you find out how much the CVjoints cost. If you can get a new shaft for less then 1000 you will be very very lucky. Usually the dealers do not have just the parts to rebuild, but I have had luck getting rebuilt at drive shaft shops. Keep it good and greased when you get it back so you do not go through it again. If a double joint, CV joint is not slinging grease, and I mean lots, you are not greasing it enough. Most call for 10 pumps on the grease gun at least once a day when being run. Word or warning, do not replace with a standard single cross joint. It will not work right. You will have to shut down PTO to go around almost any kind of corner. I have not seen any double joints at Agri-Supply, but they have lots in stock that are not listed in the catalog.
/ PTO Shaft Needed #6
Good luck finding the parts. I recently repaired a bent PTO shaft instead of spending the money on an entirely new one. Much smaller then what you have but still saved me about $150. It involved calling and visiting about 5 dealers and after I found a piece of shaft in the right size a truck repair shop pressed the bent drive shaft out and replaced it with the new piece. Luckily the joint was OK.
/ PTO Shaft Needed
Not sure if it's new aftermarket or rebuilt, but got one at the local dealer for $800. New one cost $1300.
LOT OF MISC SAWS (A62131)
LOT OF MISC SAWS...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63118)
2023 Takeuchi TL6R...
429905 (A61165)
429905 (A61165)
2004 FOREST RIVER CHEROKEE LITE CAMPER (A62130)
2004 FOREST RIVER...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
2011 Dodge 2500 Service Truck (A63116)
2011 Dodge 2500...
