PTO Shaft is turning.....
/ PTO Shaft is turning..... #1
MicroPilot
Northern KY
Cub Cadet GT3500 hand-me-down
The PTO shaft is turning even when it is disengaged. I can grab the shaft and stop it from turning and there is no force required to stop it from rotating. It just started doing this within the last week or so. What might be causing this behavior? PTO Clutch needs an adjustment? Some other adjustment? This is on a 3035.
/ PTO Shaft is turning..... #2
My C47L does it to... I've seen many/most tractors do this. Dad's MF 1135 does it.
OK, just wanted to make sure something wasn't getting ready to fail. Actually noticed this since last weekend when I did my 50 hour service.
/ PTO Shaft is turning..... #4
My 3820 does it also, I see no reason for concern.
Gene
/ PTO Shaft is turning..... #5
</font><font color="blue" class="small">( The PTO shaft is turning even when it is disengaged )</font>
My 3045 has done this from day one.
There is a PTO shaft cover that came with my tractor, but I haven't ever used it. I'd probably just lose it if I put it on the tractor, so I just keep it in my toolbox where it won't get lost - even though I don't use it /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
This has to make sense to somebody else out there - might be a good henro thread?
</font><font color="blue" class="small">( ...There is a PTO shaft cover that came with my tractor, but I haven't ever used it. I'd probably just lose it if I put it on the tractor, so I just keep it in my toolbox where it won't get lost - even though I don't use it ... )</font>
Yea, the manual says to keep it over the shaft when there isn't anything hooked up. The problem is it requires you to remove two bolts on the PTO shaft housing to keep it in place. I think I threw mine away as I needed the room in the tool box for actual useful stuff!!!
/ PTO Shaft is turning..... #7
</font><font color="blue" class="small">( I think I threw mine away as I needed the room in the tool box for actual useful stuff!!! )</font>
That sounds like a good idea! /forums/images/graemlins/wink.gif
/ PTO Shaft is turning..... #9
PTO shaft is turning ususally because oil dragging it. So, for sure, you know that you have some oil in tranny, and lubricating is o.k. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2026 Electric Tricycle (A64194)
2026 Electric...
2017 Chevrolet Impala Sedan (A64194)
2017 Chevrolet...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
Wooden Chair (A64557)
Wooden Plant Holder (A64557)
Wooden Plant...
