PTO Shaft Guard That is Easy to Deal With?
   / PTO Shaft Guard That is Easy to Deal With? #1
Suburban Plowboy
FL
Kubota L3710
I posted a thread about my bush hog, and I complained about the PTO shaft being hard to remove and install. People said they were all like that. I went out and looked at it, and I realized my problem is the guard, not the shaft. I don't know a whole lot about PTO-driven implements because I only have one. The shaft itself is not that horrible to deal with.
My guard is a Eurocardan, and I had to use a screwdriver to pry it off. It's pretty beaten up after 20 years, so rather than fix it up, I would like to replace it with a guard that is easier to remove and install. Is there a good one out there?
I see a brand called Bare-Co gets good reviews from some people. It has two levers you open to release the front cone so you can slide it back off the front of the shaft.
   / PTO Shaft Guard That is Easy to Deal With? #3
I'm thinking that most pto shaft guards are not interchangeable. I think you may have to buy the shaft too. Many of the instructions for the shafts say to trim the end guard cones to your application. With your old mower, I would just trim it.
   / PTO Shaft Guard That is Easy to Deal With? #4
The PTO guard on my Kubota was in my way. I removed it and welded a little 1/4" rod along each bottom end/edge so when I remounted it -it angled upwards more. This gives me clearance for the PTO easy connection adapter and still protects the driver.
The manufacturers claim there are universal guards.
   / PTO Shaft Guard That is Easy to Deal With? #6
I cut the bell on the tractor end back about 2 inches to make things easy.
There is no exposure that isn't covered by the guard or the tractor metal shield.
It's just a bit easier....
   / PTO Shaft Guard That is Easy to Deal With? #8
For me pull collars are harder than push button to work around pto guarding. Like the idea of trimming the bell back. Now often disconnect from implement, connect to tractor, then reconnect back to implement just because of space and guarding. I come from a time brushhogs didn’t have pto shaft guarding. We used 4” corrugated plastic drain pipe over the pto shafts to keep grass and kudzu from wrapping around the shaft.
   / PTO Shaft Guard That is Easy to Deal With? #9
For me, the PTO spline shield, which is bolted to the tractor, is more of a problem than the guard on the PTO shaft. I hate to admit it but I owned my first Kubota for several years before I discovered it could be tilted upward to allow more room to attach the PTO shaft.
As others have suggested, I trim the plastic shaft guards on some of my implements for better access.
   / PTO Shaft Guard That is Easy to Deal With? #10
That tractor guard is one of the first things that gets removed on a new tractor for me. I can't deal with them. I have 3 brand new ones in my shop.
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
New/Unused 72inch Quick Attach Vibratory Roller (A57454)
New/Unused 72inch...
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2014 Toro Z-Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2014 Toro Z-Master...
